dunndog
So drop the forks and put the shock in climb mode and think windmills then..It's like 200m difference in elevation gain over the distance.
Plenty of ups and downs, but the overall grade isn't to severe. If I can do it, your Nana could.So drop the forks and put the shock in climb mode and think windmills then..
I didn't invite you, you invited yourself. eace:Cheers for the invite! I was feeling it more yesterday than I did on Sunday.
I am taking the lucky princess away to Daylesford for the last weekend in September, do you use strava? Any chance you could PM me your ride?I didn't invite you, you invited yourself. eace:
Funnily I was pretty right Monday, that steaming bath and cold beer must've done their trick..
Not much need, it's very well signposted and the tourist info joint will be able to point you in the direction of the Daylesford entry point.I am taking the lucky princess away to Daylesford for the last weekend in September, do you use strava? Any chance you could PM me your ride?
Roger that. Thanks for the info.Not much need, it's very well signposted and the tourist info joint will be able to point you in the direction of the Daylesford entry point.
#knucklesisachunt
I have a Gpx file for the section from Sawpit Rd (Mt franklinish) to Castlemaine. I'll PM it to you tonight if that helps any.Roger that. Thanks for the info.
That would be great if you could. ThanksI have a Gpx file for the section from Sawpit Rd (Mt franklinish) to Castlemaine. I'll PM it to you tonight if that helps any.
#knucklesisachunt
No sorry, I don't. I'd be keen to ride it the other way soon, for comparisons sake. Def worth an arvo out!I am taking the lucky princess away to Daylesford for the last weekend in September, do you use strava? Any chance you could PM me your ride?
