safreek
Well bugger me, didn't spell check the spell checker, obviously meant to be lock, shall leave it for amusement sake thoughRemember to use mouthwash afterwards
Not as weird as my normal life thoughWell this is getting weird....
Yes, yes he was. I shall blame dale for my perversions, always got to pass the blameYou're the one who gave him a pump..
Yeah sure...you run with that.Not as weird as my normal life though
Is it possible to buy less than a litre of 2.5 suspension oil for the reverb
Cheers, may have a crack at it at that priceRockShox Reverb/Monarch Hydraulic Fluid Bottle 120ml
Buy RockShox Reverb/Monarch Hydraulic Fluid Bottle 120ml Now at Pushys. Lowest Price, Secure Shopping and Fast Delivery from Australia's Best Online Bike Storewww.pushys.com.au
There's some cheap bleed kits on ebay too.Cheers, may have a crack at it at that price
Sweet, will it pop up and down at least 2 or 3 times. I assume with the seat up for the bleedBleeding them is easy, just tedious. Each syringe about half full. Remove the plugs at each end and screw in the syringes then just pull and push 7,350,129.3 time until all the air is expended. Make sure the lever is on full open (I think) and then it is good. For a while. Perhaps several minutes.
Got the rocksox syringes and attachments off Dale, after the bleeding I may use them for a roid shotThere's some cheap bleed kits on ebay too.
They're a sealed system dude...you can do better than roads with it - total blood transfusion! The ultimate bleed.Got the rocksox syringes and attachments off Dale, after the bleeding I may use them for a roid shot
Needs bigger syringes.They're a sealed system dude...you can do better than roads with it - total blood transfusion! The ultimate bleed.
You mean like the yanks and their blood doping, fuck endurance, if it don't build juicy muscle, what's the pointThey're a sealed system dude...you can do better than roads with it - total blood transfusion! The ultimate bleed.
The more the merrierNeeds bigger syringes.
Or do you mean I will need a transfusion after my roids burst,They're a sealed system dude...you can do better than roads with it - total blood transfusion! The ultimate bleed.
