気が狂っている男
Put some shots of the fork up? But you're probably right - air volume is what determine your spring weight and thus sag on this fork. Have a look for info on maximum amount of psi you can crank into it, you don't want to blow it up. Add air, remove pump, bounce bounce bounce, feel good = no? Back to step 1 (add/remove), feel good = yes? Get boner and ride.
R stands for rebound adjustment. Dial to position where fork comes back at you at a rate you like. Faster for wheelies and jump, slower for not sure why.
Do you know when the fork wad last serviced? Fox forks do like regular servicing to keep the oil fresh and seals supple. You don't want to eat away the anno on those stanchions, a 1 1/8 steerer fork to suit that frame isn't going to be easy to find.
