It appears that there are some pretty pissed off jump builders because people post 'their' jumps, next thing hordes or people come from nowhere with no respect for the jumps eventually trashing them. this seems to be creating a real localism mentality not unlike surfing which I for one do not want to see happen with bikes. what guidelines should a DJ code of conduct / etiquette contain?
____________________________________________________________
[ADMIN EDIT - RYAN - Adding rules to first post]
Dirt Jump Etiquette – Compiled by Farkin.net
1. The first rule of dirt jumping is dig, dig and dig some more. Dirt jumps only exist because people build them, they don't just magically grow out of the ground. Regardless of where they are built, the people who build jumps own them while they exist, end of story.
Helping out with digging is the only way you can earn the right to ride their spot and the only way you will conceivably earn the right to have input on the way the trails progress in the future.
If you ride a spot frequently you are at the very least obligated to spend some time before or after you ride repairing take-offs and landings. If you case a landing or blow through a lip it is your responsibility to fix it. Obviously there are exceptions to this rule for visitors from out of town and so on. Apply it at your discretion.
2. Don’t assume that because you have discovered a wicked set of hidden trails that you immediately inherit the right to broadcast their location. Unless jumps are on council land assume that they are meant to be secret unless someone who is obviously a local tells you otherwise.
3. Take out what you take in. The ground around the trails is not the place to throw your empty chip packets, coke cans, busted inner tubes and used syringes. If the jumps are on private land the owners probably don’t want you using the place as a rubbish dump. Take a plastic bag with you and carry out any trash you accumulate during the day.
4. Don’t ride trails when it’s wet unless you have permission from the owners to do so. During dry months limit skidding as much as possible as dry conditions make maintaining jumps more difficult.
5. If you can’t ride a set of trails either go and find a set you can ride or ask the owners for pemission to build a smaller set. Do not under any circumstances assume you have the right to modify any set of trails that are obviously in use to make them easier for you to do.
6. Don't be a snake. If you cut in front of the line waiting to roll-in or cut someone off mid-run you are liable to be abused, threatened, pelted with debris, beaten and buried semi-concious in the middle of a jump. You have been warned.
7. If you are a minor and you have injured yourself doing something you're not supposed to do (say riding a set of secret trails out in the bush when you were supposed to be going to the shop to get mummy some milk) then for the love of all that is holy don't disclose the location of the trails or the details of your accident to your litigation-happy guardians.
Trails in Australia HAVE been plowed after parents chased down the diggers / land owners for public liability when their precious little darlings injured themselves taking a calculated risk. Be the kid who gets your local trails plowed and I guarantee broken bones will be the least of your worries.
