The Duckmeister
Has a juicy midrange
Finally finished collecting the XTR part of the build (except brake rotors, but they'll be MT900 160mm when the final wheels get built), so add to the spec list M988 "Trail" brake levers paired to M985 calipers, SM-SL98B I-Spec-B shifter caps and M9000 135x10 Q/R rear hub. Although both hubs are mismatched by series number and cosmetics, mechanically they're unchanged from their 980-series counterparts.Although assembly hasn't progressed since the last update, bits have been coming together behind the scenes.
The Spec so far:
Frame: 2012 Giant Anthem X Advanced SL, 18.5" (M)
Fork: OEM Giant blue Fox 32 F120 RLC; rebound, adjustable force non-remote lockout, low-speed compression adjustment, 120mm travel; supplied but not fitted 20mm travel spacer so I can drop back to original-spec 100mm if desired.
Shock: Fox Float RP23
Crank: Shimano M980 XTR 3x (XT middle ring), with BB93 XTR threaded bottom bracket.
RD: M985 XTR clutchy long cage for 3x10.
FD: M980 XTR low-clamp 3x10.
Shifters (yes, both of them! ): M980 XTR 3x10 bar clamp.
Pedals: M990 XTR Race, SPD 25th anniversary special edition, in blue ano finish.
Wheels: M785 XT "Race" 559 x 21mm rim, 100x15mm hub Front, M788 XT "Trail" 559x24mm,135x10mm rear.
Chain & cassette: Shimano HG 95 XT chain and M771 XT 11-36 10-sp. cassette. Have a M980 XTR cassette, but that will wait in reserve until I get the ultimate wheels.
Other: OEM Giant blue ano derailleur hanger & stem top cap; Hope Tech blue ano seatpost clamp. M9110 XTR 15x100 front hub for future build into a carbon rim...
With that side of things complete my focus now shifts to the cockpit and rims....
