Matt- D8
Hey All
A quick Service question. My 40s are expieriences knocking throughout there stoke ( travel). I am quite aware that is the spring in the left staunching/lower thats knocking/taping against the (inner) walls of the lowers/staunchings.
So first up removing the top cap is relativley easy just a ".... spanner size", do i have to watch for any "air born" springs or in the spring under relativley low "load". Plus does the spring simply slide out? or is there an attachnment on the bottom of the lowers?
Second segment- once the spring is out, i have heard of many way to stop this noise: wrapping in electrical tape, condom, heat shrink and finally a road tube.
It seamed most logical slide a road tube over the top, heaverly greased up ofcourse. What do you think?
Is there anything i should watch out for?
and re- installing- same simple process? do i have to re-aline the sping to a particular attachment point in the bottom of the left lower?
I know theres alot of questions, i would appreciate it if you could answer as many as possibe.
Cheers Matt
Cheers Matt
