hakka
There's a new firmware out today that enables Strava live segments on the Garmin 510. It doesn't come with any instructions on how to get it working.
The following process worked for me:
Plug the 510 into the pc and and Garmin Express should notify you of the available update, install the update, disconnect the 510 and reboot.
It will take a few minutes to reboot and finish the installation.
Use Garmin Express to open the Garmin Connect webpage, when its open (it took a while for everything to appear for me) click on the gear icon at the top of the segments window, and select 'use Strava segments'. It will ask you to authorize garmin to connect to your strava account (you need to do this even if your accounts are already connected). Authorizing from the strava page does not work, it must be done form the Garmin page.
On your strava page go to the Dashboard menu>my segments. Untick 'use popular segments' or it will fill your device with a bunch of roadie segments. Your starred segments appear here, these are the ones that get transferred to the 510.
Plug the 510 into the computer and Garmin express will tell you there are files waiting to be installed, click install.
On the 510 the segments can be found by clicking the folder icon>strava live segments, they can be enabled/disabled from here. Select the segment, go to leaderboard and it will give you the option of comparing your run to your PR, the KOM or the fastest of your Strava friends. The comparison can be seen on the map screen or virtual partner screen during the activity.
