Item: Giant Trance 1 2014 27.5, L, with upgraded wheels, 1x10 ready
Item Condition: Used, well looked after
Reason for selling: went to the bike shop and couldn't resist a good deal on a new Giant bike
Price and price conditions: $1500 with Stans Flow wheelset
Extra Info:
Pictures:
(More pics below)
Awesome bike right in the sweet spot where it can climb tight trails well with the lockouts and fork dropped, and shred descents too with them open and the seat down.
140mm Maestro dual air suspension, Fox triple position CTD (Climb, Trail, Descend) both ends and TALAS height adjust switch for climbing. Stanchions have no scratches.
Wheels upgraded to much wider, stiffer Stans Flow S1 rims with two through-axles - from the standard 19mm wheels and tiny fiddly 135x5mm QR to enduro style 30mm wide and a 142x12 rear through-axle with the Giant dropout upgrade kit, and fork has a 100x15mm through axle. Rims are straight and undented.
Drive train: Ready for 1x10 with just a chainring because the rear is a huge 11-42 cassette thanks to OneUp Components. Front is still a 2x derailleur with a 2x chain guide for a ridiculously wide range of gears for those of us whose knees have seen better days. XT shadow+ (clutched) derailleur replaced so is much newer than the bike model.
Dropper post works and holds in both up and down positions, normal play, stock Giant one so sometimes needs a nudge or a wiggle.
Well cared for bike, all works very well, well used with a some trail and carrying marks see photos.
Shock and fork serviced at the LBS a few months ago and sadly the bike has only been ridden a handful of times since then. Rear brake cable replaced and reinforced to avoid the known Maestro cable rub issues.
Tubeless tyres with Orange Seal, big 2.5” super tacky gravity tyres.
Can do a deal for less $ with the standard narrow wheels and 135x5mm axle with trail tyres if you want it to be more of an XC style bike.
Original info: search for “Giant Trance 1 2014”.
Extra Info:
Pictures:
(More pics below)
Size | L |
Colors | Satin Silver/Blue/Black |
Frame | ALUXX SL-grade aluminum, 5.5" Maestro suspension |
Fork | Fox 32 Talas CTD Evolution, w/15mm thru-axle, OverDrive 2 steerer, 120-140mm travel |
Shock | Fox Float CTD Evolution |
Handlebar | Giant Connect SL, low rise, 31.8mm |
Stem | Giant Connect SL, OverDrive 2 |
Seatpost | Giant Contact Switch-R, 30.9mm |
Saddle | Giant Contact, Upright |
Pedals | N/A SPD, can test on flats |
Shifters | Shimano SLX, Rapid Fire |
Front Derailleur | Shimano SLX |
Rear Derailleur | Shimano Deore XT, Shadow Plus newer model |
Brakes | Shimano SLX, hydraulic disc, [F] 180mm [R] 160mm |
Brake Levers | Shimano SLX |
Cassette | Shimano HG81 11x36, 10-speed 1x10 suitable 11-42, Shimano XT with OneUp Components 42t upgrade. |
Chain | KMC X10 Shimano HG |
Crankset | Shimano Deore XT, 24/38 w/MRP 2x Guide |
Bottom Bracket | Shimano Press Fit |
Rims | Giant P-XC2, double wall Stans Flow S1 30mm internal |
Hubs | Giant Performance Tracker sealed bearing, [F] 15mm axle, [R] 135x5mm system integrated QR Stans Neo through-axle 100x15 and 142x12. |
Spokes | Stainless Steel, 14/15g |
Tires | Maxxis Ardent 27.5x2.25, folding Maxxis 27.5x2.5 Minion super tacky DH tyres, tubeless with Orange Seal |
