Great, now I don't like my new forks - Pyga Hyrax build thread
johnny
I'll tells ya!
FRAME: Pyga Hyrax large
FORK: Lyric Ultimate
REAR SHOCK: RS Deluxe RT3
RIMS: DT Swiss Front-XM481, Rear-EX511
HUBS: Hope Pro4 boost
SPOKES: DT Swiss Comp
NIPPLES: DT Swiss
VALVES: DERT Tubeless
AXLE: Maxle Ultimate
TYRES: Front-Maxxis Minion DHF, Rear-Maxxis Ardent
HANDLE BAR: Renthal Fatbar Lite - 35mm diameter, 45mm rise
STEM: Spank split 35mm
SPACERS: FSA
GRIPS: ODI Rogues
SEATPOST: PNW Loam dropper
SEAPOST LEAVER: PNW Loam
SEATPOST CLAMP: Wolftooth
SADDLE: Joystick Binary (has a fuckin skull on it, bro!)
PEDALS: HT Industries Supreme
CRANKS: Shimano XT
CHAINRING: Wolftooth StopDrop 36 tooth
BOTTOM BRACKET: Shimano threaded
BRAKES: Front -Shimano BR-M8120, Rear-Shimano BR-m8100 (due to availability...)
ROTORS: Shimano XT - Front-203, Rear-180
DERAILLEUR: Shimano XT Shadow 10spd
SHIFTER POD: Shimano Saint
CASSETTE: Shimano XT
377026
377027
377028
377029
377030
377031
377032
377033
377034
377035
Pyga Hyrax - large
377036
Frameset: 6066 T6 Alloy – 140mm Travel
Rear Shock: Rockshox Deluxe RT3 205×57.5 Metric Trunnion
Rear Axel: Rockshox Maxle 12x148mm
Seatpost Diameter: 34.9mm
Seat Clamp: DEED 39mm
Bottom Bracket: GXP 73mm Threaded
Headset Spec: ZS44/ZS56
Fork Travel: 150mm
Recommended Axle to Crown: 561mm
Wheel Size: 29″
Max Tire Width: 2.6″
Excuse me whist that frame and I get a room.
Rockshox Lyric ultimate
Ult Charger2.1 RC2 29"
15X110 150mm
Gloss Black 42
DebAir
Wheel size 29"
Travel (mm)150mm
SpringDebonAir, Dual Position Air
Fork offset42mm
Maximum Rotor Size220mm
Upper tube type35mm tapered wall aluminum
Max Tire Width (mm)81
Minimum Rotor Size180mm
Damper TypeCharger 2.1 RC2
Volume reducer0/4 Tokens, 1/4 Tokens, 2/5 Tokens, 3/5 Tokens
Hope Pro 4 hubs
  • Silver
  • 32 hole
  • Machined from forged 2014 T6 Aluminium billet
  • 148x12mm thru axle
  • freehub10spd Shimano
  • Weight: - 300g,
I’d found a Ex511 a few weeks ago. Will see if I can remember where it was.
Wow. Just a couple of weeks ago there were a few around. Like most things they are being snapped up! As well as @slowmicks find above I found one on bike exchange through the Cyclery. $170
I never let PayPal do the conversion. They rip you on conversion, works out to be up to 5% more than your CC.
Saying that, if your CC charges you International transaction and money changing fees, it will probably not matter either way.
