safreek
He has been entrusted with historyLooks like the official XCR Club. I'm sure you will do these GT's justice.
Had the same experience stripping my old frame. Some bits cleaned up easy, but some of it was an absolute bastard.First practise run at stripping paint off. Tried sand blasting, paint is too tough, would have taken 10kg of grit to strip the rear triangle.
Chemical Paint stripper works, but this is after two applications. Going to be a big effort.
Do know the tricks of keeping the stripper wet so it works for longer? I wrapped the stubborn bits in glad wrap after applying the stripper.Yep, the karcher is going to get a work out. Today’s effort was with a garden hose, it quickly dawned on my a scraping tool sucked
I do how. Redbruce told me about this trick yesterday.Do know the tricks of keeping the stripper wet so it works for longer? I wrapped the stubborn bits in glad wrap after applying the stripper.
I’ve been using more PPE then a dude trying to screw a Nigerian lady of the night in the shadows of Chernobyl no 4.Don't forget to dress like you are on breaking bad, goggles save a lot of pain
Indeed I’ve read elsewhere leaving methylene chloride in contact with aluminium for too long is unwise.If you're using that gel type stripper give it two coats, the first coat usually gets sucked into the paint and do it in a cool spot where it doesn't dry up so quick. I'm not too sure if leaving paint stripper on an alloy from for a long period of time is a good idea. I've done a few steel frames and I've used a wire brush with gloves as the stripper softens the paint enough for it to come off easy. It's a lot easier for the paint stripper to work once the paint has breaks in it so it can get under the paint to lift it.
Generally start to feel just after it becomes really hard to wash off in my experience! Horrid stuff but very effective...Yep a buff with some metal polish and it will look great. You did well with all the protection, I coped a few burns with stripper splatter.. Takes some time before you notice it’s eating your flesh..
