slider_phil
Does that center just knock out and re-spline wherever you want it positioned? Interesting setup.
How do you get the paint out of the fiddly bits, sandblast, it just patients. When I had a crack at stripping a frame I ended up painting over the little bits that would not wire brush offThird application of paint stripper on the rear triangle. Fuck me the paint on the rear triangle is super tough. Still needs one more go.
I thought the dt240's came with the star ratchet which was a good freehub. You need more than one of those? They are dead easy to service.DT Swiss hubs acquired. Second hand, out of a trashed Enve wheel set. On the hunt for a higher POE ratchet kit now. 18poe can go jump.
WTF DT, decal orientation isn’t a thing?
It's spot on. You don't look at the front hub from the back of the bike and vice versaDT Swiss hubs acquired. Second hand, out of a trashed Enve wheel set. On the hunt for a higher POE ratchet kit now. 18poe can go jump.
OI think that Roval SP hub you sent me has DT swiss star ratchets inside it. I just counted 36 clicks for a revolution so they are probably the 36t ones. Want me to email them to you? Happy to swap for the 18t ones because the hub is used on a wheelset I use for touring.
The 350's are the same also.Google image search shows all 240’s run decals like this. Feels odd, I’ll move on.
