Majin
So I've Eventually decided to go through with building an Evil Wreckoning. As I was after a long travel 29er as more of a "Quiver Killer" rather than a XC or DH beast.
Everything has been ordered and the Frame fork and Seatpost have been Preordered through Stu @ Defcon Cycles ( Aussie Importer)
So far the spec is:
Frame: 2017 Evil Wreckoning Size L in Gunmetal
Rear Shock: Monarch RC3 ( will eventually change to a Topaz)
Fork: DVO Diamond BOOST axle in Black
Handlebars: No idea, Will be using Deity blacklabels till I decide
Stem: No idea, Will be using a Straitline 32mm till I decide on a length
Headset: FSA x Evil
Grips: ODI Elite Flow ( Black)
Saddle: Specialized Henge Comp
Seatpost: KS LEV 150mmx34.9
Front Brake: SRAM Guide RSC W/ 200mm Rotor ( Black)
Rear Brake: SRAM Guide RSC W/ 180mm Rotor ( Black)
Cranks: Raceface Turbine 170mm w/ gray crank boots
Chainguide: The built in Evil one
Chain: Shimano Ultegra 11s
Pedals: HT X2 silver/gray
Rear derailleur: Shimano XT M8000 Long Cage
Rear Shifter: Shimano XTR
Cassette: Shimano XT 11-46T
Front Hub: I9 Torch 32h BOOST Black
Rear Hub: I9 Torch Classic 32h BOOST Black
Front Rim: Easton ARC 35mm
Rear Rim: Easton ARC 35mm
Spokes: Sapim Race Black
Nipples: Sapim Brass Black
Tires: F: Minion DHR 2 Widetrail R: Minion SS
Tubes: Whats a tube? Stans Sealant
Total Weight: No idea - will post when built
Other: Wolf Tooth Dropper Remote, 32/34t RF cinch chainring
The frames rougly 2 weeks away but everything else is on its way
The build kinda got accelerated as Stu gave me a killer deal on the frame, fork and post. Shoutout to Stu and hte great service him and Defcon offer
Ill post some pics when stuff starts arriving
So far the spec is:
Headset: FSA x Evil
