How easy is it to convert between standard 24mm hollowtech and GXP? I'm more likely to have an old hollowtech BB. It looks like a spacer on the NDS between the 24mm bearing and 22mm crank would solve it. Anyone done that? I've seen them for sale on ebay but haven't jumped...I think I still have an off brand one that converts between 24mm and GXP. It was blue, if that matters…if I can find it.
Just a shim that slips in and out of NDS bearing.How easy is it to convert between standard 24mm hollowtech and GXP? I'm more likely to have an old hollowtech BB. It looks like a spacer on the NDS between the 24mm bearing and 22mm crank would solve it. Anyone done that? I've seen them for sale on ebay but haven't jumped...
And the little spacer worked fine to make it work with a GXP?DS bearing rough…probably why I removed it. I’d say you’re welcome to it, but from memory, it cost about the same new as post to you would be.
Curse of the trouserless...also what kind of person doesn't have vernier calipers??
Lip thickness if largely irrelevant. Good luck with it. Here if you need it.Thanks, reckon I can work it out from there, width of the bearing and looks to be about a 1mm thick lip.
Hey man, just did the spacer thing instead of getting the gxp bb.And the little spacer worked fine to make it work with a GXP?
What are the dimensions (other than OD 24mm and ID 22mm)? How thick and what diameter is the lip, I might just get the old man to machine one for me.
EDIT: Also does the spacer go in from the outside or the inside. Looks to me like the NDS bearing for GXP should run against the step down in the crank axle, that would imply the spacer goes in from the inside?
That may have been 100%. It’s been ages since I fitted it. Running inside looks neater, and just checked, fits the crank fine, but can’t be sure. Maybe there’s different ones.Hey man, just did the spacer thing instead of getting the gxp bb.
Myself and a bike shop tried every way with the spacer, putting the spacer inside seemed right by the way it nestled in but when putting the cranks back on they would not go on properly.
Only way it worked properly was to push the spacer into the outside of the bb, now works perfectly. Hope that is helpful @PJO
Yeah, it was odd, both myself and lbs tried inside, it just looked right but didn't work. Tried it on 2 sets of cranks and same problem.That may have been 100%. It’s been ages since I fitted it. Running inside looks neater, and just checked, fits the crank fine, but can’t be sure. Maybe there’s different ones.
That’s not how you roll.Maybe I should just buy the correct bbs
Most of the time my bikes don't eitherThat’s not how you roll.
I see what you did there. I think I saw ZTTO GXP’s on Aliexpress cheap. They have to be as durable as SRAM ones.Most of the time my bikes don't either
