Disclaimer, haven't tried this, but would think that the appropriate bolt, nut and washer combo could work.As per my “what did you with your bike” I have sourced some replacement Rivnuts, now I’ve seen some hacks for fitting them without the tool, anybody have a sure fire method that’s worked for them? Otherwise I’ll have a look at YouTube tonight
I've done this with Rivnuts/Nutserts (same thing, different names) to tighten them when they haven't initially been crimped tight enough. It works.Disclaimer, haven't tried this, but would think that the appropriate bolt, nut and washer combo could work.
Thread nut onto bolt, add washer, thread rivnut onto the end of the bolt..
Insert into hole, hold bolt head with spanner, and "loosen" nut with another spanner (i.e. try to undo the nut off the bolt).
Maybe a little grease on the bolt would help too.
I've done this too, with mixed success. A couple of times the bolt sheared under pressure. Other times I got a nice clean crimp. I wonder if the proper tools must use a hi tensile steel or something in the bit?Disclaimer, haven't tried this, but would think that the appropriate bolt, nut and washer combo could work.
Sounds like a hi-tensile bolt is required. A few cents from your local not and bolt supplier (don't go to Bunnings)I've done this too, with mixed success. A couple of times the bolt sheared under pressure. Other times I got a nice clean crimp. I wonder if the proper tools must use a hi tensile steel or something in the bit?
If you wanted my sperm, you could have just asked nicely.Why bodge it when you can just drop $300 on one of these ratcheting badboys?
Even comes with a swanky case so everyone knows you’re a wanker.
We need pictures of the finished job.Well it worked, I bodged the first one then second one took a little longer and keeping tension seems to be the key, @Ultra Lord I did think about buying a cheapie, found a couple for $30 but I decided against it.
Hack - if you doing with a bolt, washer and nut method, I worked out to get a nice rounded edge on skinny seat tube, put a brake or coned washer against the rivnut, mind you I worked this out while trying to get it a little tighter but it seemed to work.
If you’re not doing many 100% just ram that shit home with some washers and a lubed bolt.Well it worked, I bodged the first one then second one took a little longer and keeping tension seems to be the key, @Ultra Lord I did think about buying a cheapie, found a couple for $30 but I decided against it.
The guy who was supposed to be training me picked one of these up the week I started. They gave him the arse the next week and it mysteriously disappeared.......Why bodge it when you can just drop $300 on one of these ratcheting badboys?
It’s nothing fancy (don’t zoom in too hard) but it’s working and will get a lick of paint this weekend to match the others (they all got painted during the frames colour change).We need pictures of the finished job.
Yup. Some guys just want to watch the world burn.The guy who was supposed to be training me picked one of these up the week I started. They gave him the arse the next week and it mysteriously disappeared.......![]()
I thought I read you wanted whale sperm for a second there...Yup. Some guys just want to watch the world burn.
We lost our 1m verniers the same way.
.... wait, what were you measuring with 1m verniers!?
They where really handy for trimming pump impellers and measuring gasket diameters without busting out some string and a calculator. Not to mention the loss in accuracy..... wait, what were you measuring with 1m verniers!?
You mean precision f-clamps...Yup. Some guys just want to watch the world burn.
