rowdyflat
chez le médecin
Not complaining too much but while away 6 days riding the front lost all the DOT and the back started to squeal.
I bought a simple basic Shimano to replace the front and then ordered the o ring seal and piston kits .
Never done the caliper repair but i do have a few Shimano. that need it too.
Is it mainly remove any brake fluid ,pull it apart use air thru the bleed ports or water in a syringe to push the pistons out and put in square o rings and push in pistons?
BUT because they are quad pistons how do you apply pressure to get the 2nd piston out on each side ? cover the hole ?
