How many extra links to start with for the chain (11 speed)
mooboyj
Howdy,
I'm going from the following on a Santa Cruz Tallboy LT:
32 tooth chain ring
11-42 cassette
to
30 tooth chain ring
11-50 cassettee
How many extra links should I start with?
What drivetrain? Shimano 12sp has extra links compared to 11sp and earlier...
That's what the extra 2 links are for.
However, with the bigger jockeys wheels on the 12 speed RDs and the chain growth possibilities with full suspension, I'd start with an extra 4 links and drop down if the chain is too slack in the smallest cog on the rear.
I interpreted Dan as looping 50t and front ring without Derailleur.
stirk
@mooboyj don't forget derailleur size!
Heaps of info on the web's and it's the one task I've not fucked up.....yet, you'll be right.
mooboyj
Ninja edit, it's 11 speed.
I think 4 extra links would be the place to start?
The current setup shifts faultlessly and is actually really nice, but Tassie and ageing legs...
mooboyj
4 was my guess as well. Or 143.54 cm according to one of the formulas I found.
The Duckmeister
Has a juicy midrange
don’t you wrap around the 50t, and the front chain ring & add 2?
Dumb way of doing it. Doesn't allow for chain growth, nor does it allow any tolerance to increase either chainring or large sprocket.
Better way is chainring & small sprocket, through the derailleur (which is at its most retracted at this point), and pull just enough tension so there's no contact between free chain & the wrap around the top jockey wheel - I usually aim for a finger thickness gap. If there's a possibility you'll change to a smaller ring at some point, cut two extra links off. This method allows scope to increase things as well, and allows enough tolerance for chain growth.
