action man said:
ok here is the best way i have found to heal grazes (shallow wounds) quickly.
soon after the accident wash the wound in the shower and make sure you get rid of all the dirt and crap in there, use a scrubbing brush if necessary. if will sting like a bitch, but you have to have a clean wound to promote good healing.
if you have hairy limbs, then remove the hair surounding the wound. this helps to keep a clean healing environment and also allows the dressing to stick to your skin. also hair provides a growing environment for bad bacteria thats why they shave you before and operation. use clippers, but i find a razor is best.
get yourself some of those fancy membrane dressings from the pharmacy, the ones that are like sticky glad-wrap and have an absorbent pad in the middle. (just ask the pharmacist and they will know what your are talking about) get one big enough to cover the entire wound. they are waterproof and very comfortable to wear and work by keeping bad tings out of the wound and keeping all the good things in.
stick it on carefully taking care to avoid and wrinkles and creases in the dressing.
leave it on until it basically falls off. in the first couple of days with will be nearly every 18-24 hours due to the amount of weeping from the wound. this will dry up after the first few days and the dressings will stay on longer and longer for up to 3-4 days.
sure the dressings can be a bit exxy, but i reakon they are worth the money as they make wounds heal faster with les pain and without the inconvenience of having to worry about knocking a scab off by accident. it also helps having both parents as pharmacists to supply you with previously mentioned dressings.
good luck
I'm an Emergency doctor so I see plenty of this stuff. I agree 100% with
action man.
You need to rinse / scrub it (yes it will hurt. A lot) then seal it with a clean dressing. The ones he's talking about are called
Opsite and you can get them at the chemist- you need to get ones with the white pad under them, otherwise get stuff called
Meloliteto use as the pad bit. There is also stuff called
Adaptic which is like a greasy gauze. The best wound dressing is graze>Adaptic>Melolite (or the pad on opsite)>Opsite. Then leave it all in place for about 3-4 days.
Don't clean the wound with Peroxide or strong antibacterial stuff- as people have mentioned, it just kills the skin cells and delays healing.
I'll probably upset a few of the more 'herbal' types here but don't put any alternative potions onto broken skin- they aren't necessarily sterile and they won't make it heal any quicker.
PS If it's more than 10 years since you had one, get a tetanus shot from your GP sometime. It's better to have it before your next big stack...
