HT Components now available
Discussion in 'Press Releases' started by xero, Jan 12, 2016.
  1. xero
    xero Supersports
    SuperSports now stocking HT Components
    We are super stoked to announce that we are now distributing HT Components Pedals in Australia.
    First drop is here and shipping to stores now.
    X2
    pedal weight(pair) 460 g
    cleat weight(pair)64 g
    size 85 x 94 x 14 mm
    body material aluminum extruded / CNC machined
    spindle CNC machined cr-moly
    pedal bearings new EVO+ bearings system
    cleat system X1/ X1F (HT exclusive system)
    pins replaceable grip pins
    options colors
    T1
    pedal weight(pair) 368 g
    cleat weight(pair) 64 g
    size 68 x 83.5 x 16.8 mm
    options colors
    AE03
    pedal weight(pair) 352g
    size 102 x 96 x 11mm
    pedal bearings dual DU bushing + one patent bearing.
    options colors
    AE05
    pedal weight(pair) 360g
    size 100 x 96 x 17mm
    options colors
    AE06
    pedal weight(pair) 415g
    size 105 x 110 x 17 mm
    pedal bearings EVO+ system / DU bushings
    pins steel grip pins + 1mm washers
    options colors
    PA01A
    pedal weight(pair) 354g
    size 100 x 95 x 17mm
    body material Nylon reinforced composite
    pedal bearings dual sealed bearing + one DU bushing
    options colors
    AN01
    pedal weight(pair) 440g
    size 94 x 100 x 17 mm
    AN14A
    pedal weight(pair) 475g
    pins replaceable anodized aluminum pins (AHP)
    PK01G
    pedal weight(pair) 218 g/per pr
    cleat weight(pair) 48 g/per pr
    size 65 x 86 mm
    body material Reinforced composite
    pedal bearings one sealed bearing + one DU bushing
    cleat system H5/ H7 / Look cleat system compatible
    Check here for the colour range in stock now: http://www.supersports.net.au/products/bikes/ht-components
  2. jarrod839
    jarrod839 Banned
    Which stores will be stocking as interested in some of the AE03 pedals.
    Thanks
  3. Minlak
    Minlak Pyromaniac
    Throw me a set of T1's (red)I will do a long term test on them and report back....:behindsofa:
  4. Mrlinderman
    Mrlinderman Likes Dirt
    Awesome Xero, I need some cleats for the X2 soon, i heard there are 3 types with HT?
  5. SF Trailboy
    SF Trailboy Likes Bikes and Dirt
    would be interested in some reviews of the cleat system and ease of release etc...
  6. xero
    xero Supersports
    Right now For the Riders, Thredbo MTB, Strathpine Bicycle Centre and Venture Cycles either have stock or its on the way....
    Your local Fav store can order, just hit them up and tell them to get in touch!
    The link to our site shows all colours available in each model.... ( just hit the drop down box)
    X2 / T1 cleats are available in either 4 degree ( X1 Cleat )or 8 degree ( X1F Cleat ) float.
  7. SF Trailboy
    never mind nothing to see here its float they are referring to not release...
  8. ForkinGreat
    ForkinGreat Random Krishna
    Hey Xero, are the cleats for the X2 clipless pedals compatible with the TIME ATAC pedal system?
  9. xero
    xero Supersports
    No, the X2 / T1 range share the same cleat, .... slight difference from Time cleats.
    ( you do get cleats with the pedals - the X1 / 4 degree float version )
  10. xero
    xero Supersports
    Trust me.... buy them and you will love them more!!!!
  11. jarrod839
    jarrod839 Banned
    Thanks
    Have dealed with Paul at for the riders before and a top bloke so will give him a buzz.
Share This Page
