What frame are you referring to ? Are u sure it's 130mm ? I think you'll find it's 135mm as this is a common MTB frame rear spacing.I have a frame with a 130mm spacing between the two rear drop outs, is there a way to make a hub with a 120mm spacing fit
cheers
Wont that stuff the chainline up?5mm each side.
Only marginally, not really enough to cause problems, unless it was already out of whack.Wont that stuff the chainline up?
