Product Review Huck Norris anti flat tubeless protection
Welcome to the next exciting review on products provided to us by our friends at Mountain Bikes Direct. We've teamed up with one of Australia's best online mountain bike stores to bring you in depth reviews on the latest and most intriguing parts and accessories you can purchase for your bike.
The values shared by the staff at Rotorburn and Mountain Bikes Direct are the same; we have a huge passion for mountain biking! It's our pleasure to be in a great position to test, review and share our in depth details on some great products available from Mountain Bikes Direct.
342242
Item: Huck Norris anti flat tubeless protection for mountain bike wheelsets
Purchased From: Mountain Bikes Direct (Click here for the product page)
Purchase Price (approx): Starting at $46.95 for one wheel, a two wheel set is $85.95 plus postage
Usage: Mountain biking
Product outline: Huck Norris anti flat tubeless protection is intended to provide additional protection to your tubeless wheels and tyres to prevent pinch flats and does it in such an easy method by providing a foam insert that creates a pillow of sorts between your rim edge and tyre when your tyre sidewall is compressed.
Pros: Very light, very easy to install, very effective at preventing flats, makes it easier to inflate a tubeless tyre with a floor pump, buying the two wheel pair comes with packaging that doubles as a mudguard!
Cons: Absorbs tyre sealant.
Fitting: First up, ensure you order the correct width Huck Norris to suit your rims and tyres. I've installed Huck Norris on a 27.5" wheelset with a Stans Flow EX rim that is 30mm wide internally. The guideline for ordering Huck Norris is to get the one that is wider than your rim measurement so in this case I ordered the large size to suit rims 34mm to 45mm. I ordered the set too, it comes with two pieces of Huck Norris to do a front and rear wheel. It's important to note that you need to trim the length to size and it comes to suit anything up to a 29" wheel so no need to look for something that suits a smaller or larger wheel.
Fitting was totally a breeze. My method was simple. I unpackagaed the Huck Norris, let them sit on the ground to unfold and sucked the existing sealant out of my wheels using the Stans syringe. I then popped the tyre off the bead on one side, gave it a quick wipe inside with a clean towel and grabbed my first piece of Huck Norris. The idea of it is to sit between your beaded tyre where it meets the rim face and the underside (inside) of the tyre tread so when you roll over something sharp edged (a rock) or land hard (huck to flat) your tyre will not be damaged by the rim edge because there's a fancy piece of Huck Norris between the two surfaces.
With that in mind, you simply roll the Huck Norris around the outside edge of your rim and locate the first spot that will indicate where to cut the material. Hold up folks! The old saying of "measure twice, cut once" comes out in force here, make sure you leave enough play in the Huck Norris that it isn't too tight on the rim edge! Once you're sure that you're on the right spot, you mark the line you want to cut off with a sharp blade then double check it. You need to make sure you keep one of the joining tabs that run across the pattern of the material as this surface will butt up again the other end of the Huck Norris.
Now, cut it cleanly so the short side edge will sit flush against the opposing end, just to be sure it will sit snug. You then roll the other end so it is against the piece you just cut and you wrap the provided velcro strap around the two ends. I suggest using some clamps here, I have clamped the two ends together then put the velcro on to ensure it sits firmly, OCD maybe? ;)
This is the point where you can sit the Huck Norris inside your tyre and above your rim edge. You'll see just how well this setup works at this point and you'll understand why the correct measurement is crucial. It should just slide straight inside your tyre and not drop inside your rim edge and lean over the rim edge below the seated tyre surface on the other side.
Right then, this is where you can insert your tyre bead into the rim and seat your tyre. Pay some attention to where the Huck Norris thick edge sits as you seat the tyre as it seems like it can roll to one side and not be in the exact middle of the width of the tyre. You'll notice it should be pushing your tyre sidewall out and making it easier for your tyre to seat. Once the tyre was on, I rolled the wheel along the ground with a deflated tyre and made sure I could feel the Huck Norris between the underside of the tread and the rim edge, that way I knew it was in the right spot and it was actually super easy to line it all up. You'll get the best feel and impression for what Huck Norris is all about at this point too, you'll feel that magic cushion between your tyre and rim edge and your confidence should grow!
The next step is to put your sealant in. I use the Stans syringe that feeds the sealant in through the removed valve core but you can just put your scoops in before you bead your tyre if you don't do the core method. My advice though? Get a valve core removal tool, grab a sealant syringe and never spill another drop of sealant on Nan's rug again. ;) I tend to put around 120ml of sealant in but this time around I put about 160ml as the Huck Norris suggests it soaks it up a little as it has more surface to cover, makes sense.
Now is the point where you can test the theory that Huck Norris makes it easier to inflat a tubeless tyre with a floor pump. Science says it should too, the material pushes your tyre bead into the rim and should just seat itself............and it does! It was a breeze to inflate from zero pressure to 40 PSI and the bead seated itself at about 20PSI. To my liking was the fact that it was a brand new tyre too. ;)
On the trail: My timing with Huck Norris was planned. I installed it a week before I was due to fly out to sunny Queenstown in New Zealand and shred the beautiful loam, the round edged roots and the square edged rocks of the surrounding mountains. I've spent many a summer in New Zealand and have never come home without flatting tyres on trail bikes, enduro bikes and downhill bikes both tubeless and tubed. I was so confident in the science of Huck Norris that I knew I could rely on it to prevent flats. Did it work? Yep! Not one flat, only typical PSI deflation of around 3 to 5 PSI a day, no burping, no loss of sealant and no holes. Did I actually man up and try to pop a tyre on a flat landing? Did I line up every root or hard edged rock and totally smash into it? Well, yeah I did but those that have ridden the hills around Queenstown know that you can't avoid them anyway and your only option is to smash into it all!
You know that dreaded ping sound when you hammer into a hard rock? I have forgotten that sound since putting Huck Norris in my tyres, not a sound! Surprisingly though, the anti flat protection isn't the only upside I found to Huck Norris. read on.............
Huck Norris has totally changed my tyre feel. It has eliminated a shitload of sidewall roll and firmed the tyre tread surface up so my grip is more predictable than ever. Having that tubeless feel with a horizontal stiffener inside the tyre has made my ride feel really stable both in cornering and braking. I don't tend to run lower pressures purely as I like some extra feel in my tyre but Huck Norris has allowed me to tinker a little with what I'm used to and broadened my view on what can be achieved with performance on your bike through some squishy bits.
I did not notice any extra rotational weight, I didn't feel heavier on some of the 1000m vertical climbs and by the second day I was totally confident that I could go that little bit harder into some features knowing this material would hold the wind in my tyres.
Summary: Is it just a gimmick like a Power Balance Band? Did some Astrology guru dream it up and is making millions from it? I dunno about the latter but can assure you that if you have ever had a tubeless flat then Huch Norris is a deadset savior to your existence. It's cheap, it's so effective, it's so easy to install, it's simple technology that just works. You can ask yourself "Yeah righto, you didn't get a flat so how do you know it works?"..................I have gotten heaps of flats but with Huck Norris I have had not one issue with anything relating to tyres. It works for me and I'll be putting it in each wheelset I have on my rides. Honestly, I cannot see a downside to it.
342242 342243 342244 342245 342246 342247 342248 342249 342250
Comments
Has anyone running HN with Joe's sealant noticed the Velcro strap dissolve? I took my back tyre off last week and found no trace of the strap at all.....
I burped a tyre the other day for the first time (running a Polygon Entiat TR8 with 3" tyres at 15psi tubeless) so decided to look at HN or CC and stumbled upon these comments. I went to bunnings today and grabbed some k-flex tubing (they didn't have any large foam backing stuff) and installed it today. See how it goes! I forgot to weigh it lol, but definitely doesn't weigh much.
So after a little period of time running it, so far, so good. I had a little burp on the front today but the first I felt about it was just touch of squirming on heavy cornering. Pumped it back up and good to go. If the K-flex insert wasn't in I wouldn't have been able to ride it, it was that low. Super happy with it and no downsides so far.
Did a good 18km at Nerang today - just ran 15psi front and rear and the bike felt great. Pretty sure I could feel the extra dampening from the DIY CC! Very rocky trails, not many jumps etc so more testing to do but so far so good!
About 80kg. Only new to riding but giving all trails a go. Single track stuff, jumps where I can etc. Probably not much help sorry
So, I recently decided it was time to give Huck Norris a crack. I made my decision based on 1: I was going back to Hans Dampf Snakeskin on the rear, which I've pinched before and 2: It was time for Thredbo and 3: I'm a sucker for Dozer's reviews & absolutely love my Bikeyoke Revive.
I was running at around 20psi for the most part, although it did get as low as 10 for a while accidentally due to some leakage over a few days. All around, the grip was excellent & I quite enjoyed the feel in the corners over riding without it.
I've got no doubt that it saved the tire a few times on some irresponsible rock hits, especially as my mate on the same tires punched a hole in his Hans Dampf on day 2, and I was generally riding harder & treating my bike worse.
My luck did run out on day 5 though. On the last rock garden before the big creek crossing for those of you familiar with the AM trail at Thredbo. It looks like I hit hard enough to chew through the foam and still ding the rim too, with a 1cm gash in the tire.
All up, I'd still use Huck Norris. I liked the feel, it did really seem to do something at least to protect the tire and was easy as to install, even for the 26 inches of pure mtb pleasure I was riding.
Finally got around to installing Ghetto Gary K-Flex Rim Protection (patent pending).
Feel bad about the derailing of Huck Norris, so am happy if this is moved to its own thread.
Originally went overboard with 13 x 19 thickness which took up too much space inside the tyre.
Went to the smallest size 9 x 13 and fits nicely.
26" wheels you'll need to cut off like 7cm off one of the 1m cuts for it to sit nicely. Normal scissors does the trick.
Don't make it too loose in the tyre. The tubeless sealant needs space between the K-flex and tyre to spread when rotating.
Don't make it too tight on the rim. This will reduce air flow and you may not be able to seat your tubeless tyre. Also, you may not be able to deflate your tyre as the higher the PSI, the more firmly the k-flex sits on the tubeless valve hole. You can poke the K-flex through the tubeless valve with a stick to help it deflate. When your psi drops, it will be able to lose pressure easier.
As @ianganderton mentioned above, you'll most likely need to cut a U shape in your tubeless valve to let air flow through the sides. You can buy a cushcore or similar solution valve replacement but they're a bit costly.
I poured my Joe's sealant when one side of the tyre was off rather than injecting.
Below is some not so exciting images and me semi-erotically squeezing the K-flex to give an idea of how it looks under compression.
@tkdbboy I wouldn't feel bad or responsible for the derailled thread. That happened some time ago. :^)
How're you liking the Ghetto Fix?
Haven't really pushed it yet. Will give it a good flog this weekend on some rooty, rutty n rocky terrain.
Only ridden some cruisy singletrack with a bit of descending and more climbing than I'd like. The minor extra weight isn't noticed.
I put some Kflex in as well. Went with the marginally narrower one to let sealant flow.
So far I am liking it. Bike seems quieter, but I have not slammed it into anything super gnarly to test the protection yet.
I had an extra piece and the old Huck Norris, so did a very unscientific test of whacking them both with a hammer on the vice. They seemed to have similar resistance to impacts and cuts, but the Kflex feels nicer in the tyre and I think has better coverage. Also a shitload cheaper to replace when destroyed.
Could be a keeper.
Sent from my iPhone using Tapatalk Pro
I'm not bothered that this thread has some other intel included, all it is doing is making the Huck Norris better and more desirable. You buy it, you fit it then you ride it. ;)
I tip my hat to you guys being creative and inventing stuff though, keep it coming.
So i removed my rear tyre to replace a leaky valve, and had a look at how the foam has held up. Immediately noticed that there's hardly any sealant left. The foam hasn't soaked it up, but I guess with all the extra surface area, the sealant has coated everything and there's barely any left to plug holes.
Where I've cut the foam in particular seems to have attracted a lot of sealant. I'm thinking maybe some spray glue to block up the holes and make it smoother might help, anyone got any suggestions on what to use?
Maybe the answer is just moar sealant..
Similar findings here.
I also have had a few issues inflating tyres at times with a blocked valve or whatever... I just purchased some of the special valves like this https://www.mountainbikesdirect.com.au/flat-tire-defender-no-clog-valve-stems-40mm-2-piec
So see how that goes - initial impressions are positive! Can definitely inflate/deflate way more easily.
