I recently bought one of these for my trance to replace the basic shock that came with it.
http://www.cyclingdeal.com.au/buy/fox-float-mountain-bike-rear-shock-200mm-7.875-x-2/GFLOCB-303
The shock is generally an improvement over my old one, but there's two potential issues with it. It bottoms out too easily (with a medium volume spacer) and there is barely any discernible difference between the CTD settings. The old shock (fox evolution) had a smaller volume spacer and still had better bottom out resistance.
Is there supposed to be a significant difference between the CTD settings? This is a 2013 shock which I've heard weren't the best, but I'd expect to see more of a difference.
I'm wondering if the boost valve pressure is too low. Is the boost valve linked in with how the CTD settings work? If so, that might explain why the bottom out resistance is low and why the CTD doesn't work.
I need to confirm if this behaviour is normal. If so I'll just get a bigger volume spacer and eventually send it off for a tune. If not, then I'll send it back to get fixed under warranty.
