Mywifesirrational
The secret to martial bliss is to ensure all frames / bikes are the same colour, that way there is no awkward questions about a new bike build.
This bike has the worst spec per cost of any complete bike you can buy, but what is it?
Frame - Rocky Mountain Slayer XL 2019
Rear shock -Fox DHX2
Front shock/fork -2019 Yari debonair (jammed an old school Fox Ti coil in there, with old Lyrik shaft and base plate)
Handlebars - Renthal Fatbar Carbon 40mm rise
Stem -Thomson 40mm
Headset -FSA
Grips -Oury slip on's
Saddle -WTB Volt
Seatpost -KS LEV Integra 175mm
Front brake - Magura MT5 (HC1 levers), 203mm Storm sl rotor
Rear brake - Magura MT5 (HC1 lever), 180mm storm sl rotor
Cranks -Raceface Sixc 175mm (screw low BB's)
Chainguide -Oneup? Built into stays, very tidy
Chain -bling bling gold KMC X11 sl
Pedals -XT trails / DMR vaults, depending on the day
Rear derailleur -XTR mid cage
Rear shifter -XTR
Cassette -Hope 10 - 44t
Front hub -Hope Pro4 straight pull
Rear hub -Hope Pro4 straight pull
Front rim -Stans Flow Mk3
Rear rim -Stans Flow Mk 3
Spokes -DT swiss Comps
Nipples -DT swiss brass
Tyres - HR2's, 2.5's, 3C mass terra
Tubes -less
Total weight - Not sure, 14.5kg by the feel of it
Stem -Thomson 40mm
Headset -FSA
Saddle -WTB Volt
Rear shifter -XTR
Tubes -less
