I'm a sit down to climb guy. (If I'm not walking)Your seats are very high:tsk:
I am beyond impressed with the 35w wheels.How do you find the 35W wheels?
I initially had some trouble setting up the jade. I ran a 450lb spring on the rc4 and found in the jade i was bottoming out too easily after filling up the bladder to the max pressure.how do you find the DVO Jade Shock on the Rune?
Bit slower than the Topaz though...I initially had some trouble setting up the jade. I ran a 450lb spring on the rc4 and found in the jade i was bottoming out too easily after filling up the bladder to the max pressure.
Also found after a pretty chilled ride at lysterfield there was oil leaking from the damper.
Sent some photos through to ronnie at dvo and he arranged for it to be send to nsd for a service under warranty. I sent it away and had it back within a week. They changed the seals and put a heavier weigh oil in it.
I picked up a 550lb cane creek vault spring for it and since the service and the heavier spring it has been flawless. Sensational small bump sensitivity.
The think the rc4 was an amazing shock in terms of how much it could be adjusted particularly with the bottom out control. Mine was due for a service and the dvo was on sale so i grabbed it.
It does play very nicely with the rune once set up correctly just not as versatile as the rc4 in my opinion.
Unless you were riding my rune...Bit slower than the Topaz though...
Good point!Unless you were riding my rune...
Flogging off AND selling your parts.Sold the rune frame.
Felt the large was a touch too small for me always having a heap of seat post exposed. I had dreams of slamming the dropper post to the collar. Checking the geo for the new frames the 2018 large has a 20mm shorter seat post than my old 2014 but a slightly longer reach. I couldn't deal with any shorter so i ordered an XL frame. Grabbed a slightly shorter stem as the reach on the 2018 xl would be 28mm longer, with the 35mm stem it will only be 13mm.
Bunch of the parts are new but the drivetrain and brakes and bars i have brought over from my old rig.
Still waiting for most of the bits but here is the build list:
Frame: 2018 Banshee rune XL Stealth black w/DVO Jade
Headset: Hope pick and mix
Handlebars: Raceface SixC 35mm
Stem: Hope AM/FR 35
Fork: Cane Creek Helm Air 170mm
Seatpost: KS Lev integra 150mm w/ southpaw lever
Wheels: Hope tech 35w BOOST w/ 203mm Hope rotors
Tyres: Front: 2.6 WT DHF Rear: 2.5 WT DHF
Brakes: Hope Tech 3 V4
Cranks: XT m8000 w/ one up 32t nw chainring
Derailleur: XT m8000 11sp
Shifter: XTR m9000 11sp
BB: XT m800
Keen as to get this build and go for a ride.
Special mention the the azza for flogging off my parts whilst i am away overseas and enabling these purchases!
These are the two bikeparks closest to homeGreat build! What’s the terrain like where you’re headed?
