petertronica
I rode at Lake Mountain on 31 December 2014. There have been some changes made to the blue track – the guy was actually on the excavator modifying a separate trail while we rode past on our second lap, so it appears the modifications are on-going.
Both my riding buddy and I were dismayed at what they’ve done. I’ve messaged the Lake Mountain facebook page to find out who to raise my concerns with (no reply yet), but in the meantime I thought I’d share what’s happening.
The section of the blue trail that has been changed is the longish downhill part at the end of the first half of the loop, it kinda comes out at the road. (the last part of this section http://www.strava.com/segments/7081648) It was previously singletrack, with lots of natural rock outcrops alongside the trail causing the trail to be narrow and technical. There were some tight corners, but the trail flowed very well and drainage was good. Skilled riders could ride this section at high speed, lower skilled riders could still ride this section well but at lower speed. I thought it was quite hard for a blue trail. (Maybe this was the problem?)
After Modifications
A digger has been driven down it, and the trail has been flattened and widened to at least a meter wide in all places, mostly 1.5m – it is entirely artificial. Large (huge) berms have been built around many corners (though not necessarily in the right places). All rocks have been removed. There are no jumps. The trail is now fast for all users. Little skill is required.
So what’s the problem
All of the natural features have been removed, and in its place we have a homogenous flat pavement. Sure it’s fast, but the old trail was fast too. Maybe not the first time you rode it, but with practice it could be ridden very fast by a skilled rider.
The old trail was unique – there wasn’t another trail exactly the same anywhere. The modified trail is practically a carbon copy of every other ‘flow’ trail in the world.
Sure, first-time riders can ride it, but the climb to get to the start of the ‘flow’ part is still really quite technical. If you could make it up the technical climb, I think you’d have no problem going down the (previously) technical track too.
If they’ve modified this trail for beginners, then sure, the beginners will thank them at first, but as soon as they’ve progressed past beginner status, they’ll have nowhere to progress too – you’ve just removed the best technical trail in the area.
You already have beginner trails here – loads of them. If you wanted a beginner trail to link up the top of the hill to the road (where this trail currently goes), why didn’t you put in a separate trail? Why did you have to change a perfectly good trail?
And finally - there is a ‘flow’ trail just down the road, it’s called Buxton!! Anyone who wants to ride fast berms and jumps can and does go there instead. At least Buxton has loads of jumps.
So besides whinging, what can I do about it? Does anyone have the IMBA handbook, and does it offer any guidance when modifying existing trails? Are there any guidelines to follow? If not, I will suggest (politely) to Lake Mountain Management that they should follow some, maybe something like these: (or do better guidelines already exist??)
(Suggested) Guidelines for modifying existing mtb trails
-The overall character of the trail should be maintained
-Does the trail incorporate any natural features? If so, these should be retained.
-Trails should not be widened unless it is unsafe not to.
-Only material found on site, or in the local area, should be used
-Consider the riders who use the current trail – are you intending these to change? Changing the difficulty level of the trail may make this trail unrideable (too hard or too easy) for the current trail users.
-Only use an excavator as a last resort.
I'm starting to think Team Robot summed it up perfectly:
http://theteamrobot.blogspot.com.au/2013/12/imba-was-here.html
I’ll add the photos Grant took when he sends them to me.
Also, please note that the new trail is still bedding in, so take it easy on the berms.
After Modifications
