link1896
Mr Greenfield
I'm picking this up from a work mate, it was too much bike for him, he only ever used it for XC/trail riding. A long standing agreement has come to fruition. This makes bike no 8. I'll have every category I care about covered.
Some of the build kit is a bit odd, especially considering the eye watering RRP of $7200 these things had.
Frame - 2015 LaPierre ZestyAM 827 medium. Carbon front triangle, alloy rear.
Rear shock - Rockshox Monarch RT3 high volume with e:i.
Front shock/fork - Rockshox Pike RC3 Solo Air 150mm
Handlebars - Renthal Fatbar lite
Stem - Nico Vouilloz Signature 55mm 0 degree
Headset - FSA
Grips - Junk lockons
Saddle - SDG
Seatpost - Rockshox reverb stealth (and it needs a rebuild)
Seat Collar: Lapierre OEM
Front brake - XT with 180 mm centreline rotor. Will be swapped out for Guides
Rear brake - XT with 170 mm centreline rotor. Will be swapped out for Guides.
Cranks - SRAM X0 carbon PF30
Chainring - SRAM NW 30T
Chain - KMC X11SL DLC Black
Pedals - Crankbrothers Candy for now.
Rear derailleur - SRAM XX1
Rear shifter - SRAM X1
Shift Cable - generic
Cassette - Sram x1 10-42
Front wheel - SRAM Roam 40
Rear wheel - SRAM Roam 40. Bearings are rooted, rear wheel has 10mm deflection.
Spokes - Bladed straight pull. Rear tension is so low, hold the brake on, wheel rotates 25mm and the hub squeeeeeals!
Nipples - alloy
Front Tyre - minion dhf 3c exo
Rear Tyre - minion dhr2 3c exo
Total weight - don't know yet, 13-14kg at a guess.
There is no longer a distributor for Lapierre in Australia, Advanced Traders dropped the brand. Warranty support through to 31st December 2017, then its factory direct I guess. I knew this before buying.
Instantly being replaced before I ride in anger will be brakes, grips, pedals for Guide RS, mullets, Oury. Plus rear hub bearings and a rear spoke tension adjust.
Headset - FSA
Saddle - SDG
Nipples - alloy
