G1 3" rc4. I think it'll bind because I'm fat. It would be fine otherwise because of the extra spacing.
It shouldn't matter if your fat. The spring still moves the same distance to reach bottom out.
If you were 50kg with a 200lbs spring on it or 300kg with a 2000lbs spring on it the spring still moves the same length to reach full travel.
Whether it binds is purely down to free length and spring compression required to bottom out, your weight doesn't matter.
You should bottom out the shock occasionally it means you're using full travel. if the spring bottoms out before the shock = bind. If the shock reaches bottom out first than no bind.
note: Adding preload takes away free length so if you need to run lots of preload to get the lighter spring to work than you most probably will coil bind with a 2.75.
