It is significant in that it has entered the construction layer, ie not superficial.I don't have any better pics as I have put some nail polish on it already.
It did look like there were one or two fibers that had split
Im still running it now, As far as concern, its my first carbon rim so was unsure as I've heard the horror stories, I'm just gonna keep an eye on itHonestly, I don't think is that bigger of a deal. I have about 4 similar gouges and have kept on eye on them. They haven't gotten any worse and its been 6 months now. I've even cracked a spoke eyelet on the rear. Im running the DH version on my All Mountain bike. If your concerned about that kind of damage to a DH rim, then maybe carbon might not have been the best choice for you, as that will most likely be the first of many. Unless your planning on changing builds often.
Bwahahah! Rider defect!You can't seriously expect to claim warranty on that. Warranty covers material and manufacturing defects, not rider defects. As for crash replacement policy, your best bet would be to contact them.
Given the 30mm rims had the bead hook, regardless of whether you can swing a crash replacement, you can at least upgrade to the hookless version. Mine are still going strong after 9 months and by most accounts on MTBR, most others' hookless rims are holding up well compared to the bead hook rims.Riding cressys at the youyangs today, and smashed my rear wheel into a large exposed root at the top of the track.
Cracked the rim pretty bad, its a LB 30mm 26" rim.
What are LB like with warranties/replacements?
Might as well try, not holding my breath though.You can't seriously expect to claim warranty on that. Warranty covers material and manufacturing defects, not rider defects. As for crash replacement policy, your best bet would be to contact them.
Was running 25psi, nothing super low but Im 70kg's on a bad day, less on a good day.Bwahahah! Rider defect!
Actually, I'd have a go at too low a pressure. Sputnik might be a victim of the popular myth that the wider rim magically enables 5psi less - result is the less than happy cracked rim from just a root ;(
Bingo, those fuckers between the trees.If its the set of roots between the trees of roughly the third straight, those roots should not destroy a rim ever. flat entry and exit, nothing weird would be happening with the suspension - presuming it is those roots, as they are the most exposed.
If you don't have the lightest layup, I'd be arguing for warranty replacement as well, should not have broken there, suggests to me the rims aren't up to the standard they should be.
Mate broke his front LB rim, on quite a sedate section of track, no warranty, crash replacement was 20 less than retail, he's not exactly telling people to rush out and buy them.
Running my wide rims at <20 PSI at 105 kg, no dings, burps or anything, wide is awesome
Also consider those who have no problems are less likely to post up saying that everything is fine.Seem to be a lot breaking, is everyone going the lightest layups or are the DH version dying as well?
Popularity must have a lot to do with it, there is a lot out there.
Zelvy, lifetime crash replacement, suddenly double the price is really quite reasonable.
Wow, can't believe those roots did that. Did you plow them or pop over a couple and land awkward on some or something?Bingo, those fuckers between the trees.
Was surprised, but oh well, Ill go stronger with the replacement.
Just touch it up a bitAnnnd Im going to support my claim by posting what I just did to my front rim. I reckon I can true it out yeh?View attachment 315293
Not too sure, They were built by FTR, the spokes were not hugely tight. I think I know what happened. I jumped into a rockgarden and the rim sort of smacked between two rocks, which caused my tubless to explode. So I reckon Ive twisted the rim on impact, would have destroyed a alloy rim no sweat. The whole rim has ovalized too.What tension is that built to? Looks like it's pulling apart fom overtensioning.
