Diablo
Delmar - Is there enough candlepower on med in the diablo? Sounds like I might need a piggyback battery to run it on high for any length of time. Would you recommend a diablo? Any negatives with the piggyback?
My main requirement is for a lightweight powerful head unit. I was considering ay-up but they just don't have the punch nor the 'smarts'. The 40% power upgrade is simply a resistor replacement to bring them from 0.5a up to 0.7a. I am sure the exposures run a constant current supplier such as a unit supplied by taskled. The MaxxD is temperature regulated which would indicate they are pulling at least 1A on high setting. I was also considering a trout light, and admire the whole 'man turning a mill' from his garage but there are cons to his setup as well.
