Isaakk
Can't think of a catchy name, so have just been calling it the Marino 130. Ordered in August 2019 & finally built mid January, it was a long process of ordering/manufacturing/delivery/building, but i'm glad I did it. Couple small things I wish I changed - more travel (why I went 130mm i'm not actually sure), better bottle mounting options (can't fit one in the frame, even though there are mounts), & an additional -10mm BB drop. Everything else I am absolutely happy with, welds are good, built 100% to the spec I provided, with a few changes over the process.
Rides very aggressively, the harder you push it the more it gives back.. still climbs 'aight, if not a little slow in tight corners. Definitely held back by suspension travel & not geometry, i'm thinking I might take out the angleset and pull it back to 64deg HA.
Frame: Marino single pivot - 130mm travel,62.5deg 64deg(?)HA (-1.5deg Works Headset), 77deg STA, 470mm reach, 440mm CS, -30mm BB drop
Fork: 2020 Pike Ultimate RC2 29", 150mm, 42 offset
Shock: DVO Topaz T3 Air, 200x57mm
Wheels: 29" DT Swiss XM1501 Spline One 30 (XM481 rims, 240 hubs)
Tyres: Front 29 x 2.5 Maxxis DHF EXO MaxTerra / Rear 29 x 2.5 Maxxis Aggressor EXO
Bars: Nukeproof Horizon Carbon - 780mm, 31.8
Stem: Nukeproof Horizon - 50mm, 31.8
Grips: Revgrips Pro
Saddle: WTB Volt Team
Post: OneUp 210mm, 30.9mm, ZTTO lever
Post Clamp: Wolth Tooth
Front Brake: XT M8100, 180mm IceTech Rotor
Rear Brake: XT M8100, 180mm IceTech Rotor
Pedals: Nukeproof Horizon CS Trail, or OneUp Alu flats depending on mood/day
Cranks: XTR M9020
BB: XT BB-MT800 External threaded
Chainring: OneUp Oval, 30t
Chain: XTR 11sp HG-901
Shifter: XT M8000
Derailleur: XT M8000
Cassette: Garbaruk 11sp, 10-46t, XD driver
Weight: 14.3kg from memory, with an inaccurate eBay scale
Grips: Revgrips Pro
Cranks: XTR M9020
Shifter: XT M8000
