That's interesting to hear. Have you had a chance to get them on dirt yet
Have folding 2.3, haven't weighed them, but they don't feel super heavy. Grip on pavement is stoopid good, have only had them on BMX, pump and 'burban jumps, so realitivly hard packed dirt surfaces, grip is only a little less than the pavement, and miles ahead of the HRs I had on before. But I'm a fat cunt.Dth stands for 'drop the hammer'............. they were primarily designed as a bmx race tyre. Unless you get the folding 2.15 they are heavy as fuck. Over 700g. The grip on all concrete surfaces is fantastic but i find the grip on dirt to be sketchy. Unless it's super hard pack. But I'm a feather weight.
Ikons are pretty good too, XC light, and have a bigger bag:stated size ratio than ardents.My absolute favorite on dirt is the Ardent Race. 600g folding at 2.1 with the non beefy side wall for 26. For the maaaaybe 10g you'll save with a folding tt, you get a 600x better tyre. Due to the small tight pattern the only surface it hates is mud.
Holy shit! You must bounce around pretty hard on 80psi???I don't run anything except tt under 65psi. My sb8 i ran at 80psi. They aren't good for street, true. I find it easier to have multiple bikes rather than suffer using a bad tire. A mate used to run DMR motos (not digger). They hooked up better in dirt for me than tt. I have some dmr transition tires for 24, over 1kg a pop....
Burban jumps sound like something a bunch of southern Hill billies have made while moonshine senseless and then punched into on their flogged out quad...burban jumps
Going to get the 2.15s for the death trap, I'm putting together for the wife. She'll be riding predominantly mixed use paths and basic single trail, so should be spot on.
Plus if you have a hunt, you can get them in uber hipster, tan wall.
#knuckleswasadrunkenchunt
No actually. That's why i loved them. They still has tons of grip even at that pressure. I can't deform the table tops to make any use of the tred (it's all on the sides)-i really am a feather weight-unless the pressure is so low i stop rolling. The pattern on the Ardent Race is tight enough that it doesn't need to deform. If that makes sense?Holy shit! You must bounce around pretty hard on 80psi???
I ran K-rad for a while. So many wipeouts, i found them not so grippy. They also cut/tore easily (my home town has a lot of those dickheads that throw glass out the window). Rolled really fast though.Kenda Krad sounds like it will fit your needs.
Skinny with tight tread pattern, fairly fast rolling and can hold decent pressure. Only thing is they are heavy
Best tyre I have had for park has been Geax Booze light, though these did not last long and were around 2.5" wide. They rolled very fast and gripped dry sealed surfaces really well. (no grip on wet surfaces)
Yeah, just looked them up and They do look good. One extra row of knobs vs an Ardent Race i think. And with weights as low as 480g for a 26x2.20--i'm in luuuuv. I got the Ardents for stupid cheap from Pushys, like $50 for the pair.Ikons are pretty good too, XC light, and have a bigger bag:stated size ratio than ardents.
