SA Mint condition -2018 Specialized Stumpjumper Comp Carbon - Medium - Now SOLD
MTBcrash
Happy to ship interstate through pack and send. Rough estimate is $80-$100 to most eastern states
Item: Up for sale is a mint condition 2018 Specialized Stumpjumper Comp Carbon in size Medium - Colour is gloss carbon/chameleon - Looks sweet!
Item condition: Has seen easily under 250km of use and has very minor scratch here and there. All parts are original including the grips and tyres. Wheels have been converted to tubeless. Bars have been cut down to under 700mm but i also have a set of 800mm wide Spank Spike Vibrocore bars in the shed. Few speckles on brake lever.
Reason for selling: Bought for my partner earlier this year for $5,500 but selling because she doesn't ride it enough.
Price and price conditions: SOLD!!!
Extra Info:
Comes with SWAT KIT.
Below is a review. https://www.bikeradar.com/reviews/b...stumpjumper-fsr-comp-carbon-650b-2018-review/ Here is the link below to website for specs and write up. https://www.specialized.com/au/en/stumpjumper-comp-carbon-650b/p/129039
TECHNICAL SPECIFICATIONS:
DRIVETRAIN CHAIN KMC X11, 11-speed w/ Missing Link
BOTTOM BRACKET Race Face PF30 CRANKSET Race Face Aeffect, PF30
SHIFT LEVERS SRAM GX, trigger, 11-speed CASSETTE SRAM XG 1150, 11-speed, 10-42t CHAINRINGS Steel, 30T
REAR DERAILLEUR SRAM GX, long cage, 11-speed
SUSPENSION
FORK RockShox Revelation RC, Solo Air, rebound / low speed compression adjust, tapered steerer, 46mm offset, 15mm Maxle® Stealth thru-axle, 15x110mm Boost™, 150mm of travel
REAR SHOCK RockShox Monarch RT, Rx Trail Tune, AUTOSAG, rebound and 2-position compression adjust, 197x48mm
WHEELS
FRONT HUB Specialized, sealed cartridge bearings, 15x110mm spacing, 24h
REAR HUB Specialized, sealed cartridge bearings, 12x148mm thru-axle, 28h
INNER TUBES - Tubeless
SPOKES DT Swiss Industry, stainless, 3-cross, 2.0" RIMS Roval Traverse 27.5, hookless alloy, 29mm internal width, tubeless-ready, 24/28h
FRONT TIRE Butcher, GRID casing, Gripton compound, 2Bliss Ready, 27.5 x 2.6"
REAR TIRE Butcher, GRID casing, Gripton compound, 2Bliss Ready, 27.5 x 2.6"
COCKPIT
SADDLE Body Geometry Henge Comp, hollow Cr-Mo rails, 143mm
SEATPOST Command Post IRcc, 12-position micro-height adjustable, alien head design, bottom mount cable routing, remote SRL lever, 30.9mm, 125mm of travel.
STEM Specialized Trail, 3D forged alloy, 4-bolt, 6-degree rise
HANDLEBARS Specialized, 6061 alloy, 6-degree upsweep, 8-degree backsweep, 27mm rise.
GRIPS Specialized Sip Grip, half-waffle BRAKES
FRONT BRAKE SRAM Guide R, hydraulic disc, organic pads, Guide S4 4-piston caliper, 200
REAR BRAKE SRAM Guide R, hydraulic disc, organic pads, Guide S4 4-piston caliper, 180 rotor
ACCESSORIES PEDALS Specialized Platform, Cr-Mo, 9/16" spindle
FRAMESET
SEAT BINDER Alloy, 34.9mm
FRAME FACT 9m carbon front chassis w/ Specialized M5 Aluminum rear end, 27.5 Trail Geometry, SWAT™ Door integration, PF30 BB, fully enclosed internal cable routing, 12x148mm dropouts, sealed cartridge bearing pivots, replaceable derailleur hanger, 150mm of travel.
Pictures: In comment below...
