G
Guest
Guest
thats about right
The biggest or main advantage of that mod is to make the rear end more progressive. Somthing all DH should be IMO.MrPlow said:I put your shock position modifications into the linkage program, and it makes a difference, I reccomend all racey owners do this mod, It increases small bump sensitivity, rises nice and straight to full travel for larger bumps, reduces head angle and bb height, and increases travel by around 12mm :shock:
Good work :wink:
Which is what I said :wink:Gutty said:The biggest or main advantage of that mod is to make the rear end more progressive. Somthing all DH should be IMO.MrPlow said:I put your shock position modifications into the linkage program, and it makes a difference, I reccomend all racey owners do this mod, It increases small bump sensitivity, rises nice and straight to full travel for larger bumps, reduces head angle and bb height, and increases travel by around 12mm :shock:
Good work :wink:
I think they feel nice, and for the money you can't go wrong really, I picked up a spare set for under $200.00. I am going to mod them by putting a grease port in them near the wear bushes I think, the ones on my bike are pretty dam smooth, provided you keep the lube up to them :wink: I have never owned a set of boxxers or monster T's to know whats better, but I don't plan on upgrading them as I don't believe the bike is the limiting factor, it is me...Damo said:Wat are those RST's like? they look pretty solid...
Oh, i took you "rises nice and straight" coment as meaning it felt linear........never mind me.......... :?MrPlow said:Which is what I said :wink:Gutty said:The biggest or main advantage of that mod is to make the rear end more progressive. Somthing all DH should be IMO.MrPlow said:I put your shock position modifications into the linkage program, and it makes a difference, I reccomend all racey owners do this mod, It increases small bump sensitivity, rises nice and straight to full travel for larger bumps, reduces head angle and bb height, and increases travel by around 12mm :shock:
Good work :wink:
