Im afraid thats the older juicy rotor for you.Well as you read, when ever i put on my rear brake, even lightly, it makes a 'flutter flutter' noise, like the pads crooked and hitting the holes in the disc.
I've had it for about 3 months, and i was wondering if it's normal and if iti'll go away. I believe it is worn in
Nah they're the new ones, it's an 07 or an 08 juicy 5. I think i might try the sand paper idea, how much sanding should i do?Firstly, to the op, what size rotors are you running? Secondly, are they the old polygon rotors as shown in previous pic, or are they the new ones?
Thats a golden solution that..sure its just pad on rotor making sound and not vibrations from having loose caliper/adapter bolts amplifying it? my code's were doing it, i was getting really angry then i relised my calliper was loose..
They still make the noise, but its not as bad as it used to be.. if anything its good, as i dont use the brakes becuase i hate the noise.
They aren't suggesting he sands the rotor, its the pads that you sand. Bit of wet and dry should help. Are they the stock pads???I wouldn't go sanding anything, you'll just end up with a bogan looking sanded rotor thats less efficient.
Sanding a rotor will make it brake better, not worse.Mate, I have the same issue with my juicy seven rear 7" but the front 8" has no worries. They are the current rotor shape.
I wouldn't go sanding anything, you'll just end up with a bogan looking sanded rotor thats less efficient. I just put up with it, as it's not a full time thing, but you could try an aftermarket rotor, there are plenty available.
Depends on how you look at it.Sanding a rotor will make it brake better, not worse.
Try getting new pads. In my experiences, Avids make that noise until you change the pads, I don't think its the rotor. I ran an Avid rotor with a Saint for a long time and it didn't make any noise, so I don't think its the rotor.
You're not going to be removing a considerable amount of metal. If you do, you're a fucking idiot. You use an extremely fine grit sand paper and lightly sand it to create a rougher surface for more friction. Whats gonna bite better, a smooth, glazed surface or a rough as hell surface?Depends on how you look at it.
Sanding reduces mass, reduced mass equals lessened ability to deal with the generated heat, hence less efficient.
If you are trying to say that its benificial from a friction point of view, then surely more aggresive pads would be the logical way to go, rather than "backyarding" a perfectly good rotor?
I had the same issues a while ago and took the following steps in order:Go with Koolstop (as suggested earlier) or others as mentioned. Money VERY well spent IMO, regardless of the age of your current pads.
