Wonder how much this weighs given the Diamond was heavier than the Lyrik or the 36. They have been dragging the chain getting this released for so long and now with the 37mm stanchions of the Mezzer plus the alleged Fox 38 coming out I wonder if they've missed the boat?New DVO Onyx for the 29ers, looks like it'll come in at the same price as the Mezzer with a 1049USD price tag.
I'm sure it'll be stiff enough too and those in the know will know it'll be a great fork but the mtb marketing machine will have over run them by that point and everyone will be calling them noodles lolClaimed weight at 2290g. I'm sure they'll be stiff enough, smaller diameter tube with more material on it is likely the name of the game there.
Mojo also offer a conversion kit to turn your fox 36 into a reduced offset dual crown fork.Which will bring on the triple clamp 36 route. Which I'm really kind of looking forward to.
https://mrpbike.com/products/bartlett
Oh Bartlett, you gorgeous idea you.
Fluids should be fine by all accounts. You should, however, remove the IRT and lube up the shaft and seals with some slicko before riding.My pair turned up yesterday. Look like a solid bit of kit.
I have read that over on MTBR. That's easy enough to before I mount them.Fluids should be fine by all accounts. You should, however, remove the IRT and lube up the shaft and seals with some slicko before riding.
A man of impeccable taste.....I have read that over on MTBR. That's easy enough to before I mount them.
Proof below haha
I will have to see how mine go. I read some people have been lucky not had any play. Frame won't be here for another 6 weeks so will have to wait.Hayes got back to me regarding the issues with the Mezzer. Turns out it's a "larger than expected initial run issue and the lower replacement solution is still several weeks out."
I get real mad sometimes.
- Spend $1500 on a fork.
- Consider yourself lucky if it works without fault, out of the box.
This industry man, never fails to disappoint.
Funny you mention, because what really pisses me off is when it is up to workshops to offer aftermarket services such as blueprinting (make sure bushings are aligned, and not too tight or too loose, ensure no excessive grease in air springs, correct oil levels etc) when really it should be the job of the manufacturer . But instead they release a fork that is 'good enough'I get real mad sometimes.
Like I remember the amount of times my 36 went for warranty before it got put on the bike.
Bikes are fun, the industry isn’t.
