I have 3 rides on my new XT 1x11 now. The 1st 2 were fine but just before the 3rd I noticed I’d left the clutch off. So I flipped it on and off I went. The clutch was way too tight and I broke a tooth of my 42, it’s now a 41 :-/
Make sure your check and adjust your clutch tension before riding. I now have mine set very light.
Cheers
Hi flint,
I discovered last night, after 9 months of abuse, my rear mech's clutch was tighter than a teens grip on a boner. It's an SLX shadow plus. Still worked ok but was adding pressure on the drive train.
I greased up the clutch and cam and now its running firm but butter smooth.
It's not so easy to adjust the tension on the shimano gear without semi dismantling but I found lube makes the difference between a tight cranky clutch and a sweet smooth one.
The factory skimp on lube, bored worker, dab dab that'll do.
Lube it up, a tight but smooth clutch is so quiet.
