Newb question
tasty.dirt74
Sorry to all who read this and think " well, durr... that's easy". Can this bracket be replaced easily with one that raises the front derailleur a smidge?
The adjustment is maxed out and as a result the front derailleur cannot clear the big dog..
The result is the bike is effectively a 1x9..! 53x26 I think is the gearing?
Now, this is a Frankenstein that was a 3x and now is a 2x using 10 speed ultegra cranks with a 53 tooth chainring.
First road bike and a steal at $250!
Cheers for any help.
you'd need a custom one or file/elongate the hole - its not far off getting proper clearance
Looks to me like it's a Giant OCR or Defy from between 2007 & 2012-ish. The hanger is optimised for a 50T max big ring; try replacing it with one from an '08 or earlier TCR, which kicks up a bit higher to give more clearance, or just file the top of the slot out a bit, but be careful and keep an eye on it, because they can be prone to splitting.
Good spotting.. its a OCR from 06-07 i was told.
I suspected that you could swap it out. Thanks for narrowing it down.
If you can remove the bracket you could alway use a clamp on bracket (see below) which will allow you to put the front derailleur anywhere you like. Pretty easy and cheap item to find online or at a decent LBS, just make sure the clamp is the right size for your frame.
lovely.
so,...that is a clamp on derailleur bracket as opposed to a braze on?
lovely.
It's a clamp-on adaptor for a braze-on derailleur....
Problem with such a beast in this case is that the existing mount bosses may interfere with the clamp band & prevent it being fitted.
