Magura Gustav is back and it’s plastic umm carbo stuff.
MacAskill approved.... well sponsored but seems to like them
jeez, he's riding an Eeeeeb tooMacAskill approved.... well sponsored but seems to like them
Magura
I can't really judge too harshly, I am in the Eeeeeb manufacturers target demographic![]()
Yep bleed screws strip if you even sneeze near them, had a set on my Focus the braking was great but between the bleed screw issues and the actual feel of the levers, I just couldn’t gel with them, it’s probably why people go Shigura.Danny has more skills in his braking finger than my whole body! I am sure they are nice brakes but Magura insist on using the plasticy master cylinder and so many reports of stripped bleed screws or cracked master cyclinders makes it a no for me. Would just get some Hopes.![]()
on the topic of stripped screws... Try a set of the Wera hexplus allen keys. They really come into their own when working on tiny 2mm allen heads which often strip out, or softer/cheaper bolts of any other size.Yep bleed screws strip if you even sneeze near them, had a set on my Focus the braking was great but between the bleed screw issues and the actual feel of the levers, I just couldn’t gel with them, it’s probably why people go Shigura.
The biggest problem is the screw is made of plastic and being so freaking fragile that threads just fail, this image makes look nice & sturdy but that’s T25 head.on the topic of stripped screws... Try a set of the Wera hexplus allen keys. They really come into their own when working on tiny 2mm allen heads which often strip out, or softer/cheaper bolts of any other size.
You come down to Hobart if you are after a bit of nostalgia.Never owned a set.
DM has been on ebikes to climb crazy stuff for about 3-4yrs. Some good vids of him doing high mountain epic rides around Scotland.
Good old Scottish/Irish weather, glad to see the end of that![]()
Plastic screws anywhere, are the work of the devil!The biggest problem is the screw is made of plastic and being so freaking fragile that threads just fail, this image makes look nice & sturdy but that’s T25 head.
I have 2 bikes with Magura MT5s and am a big fan. Never had an issue with the screws while bleeding them. Just tighten them as if you are tightening a plastic screw and you will be fine.Yep bleed screws strip if you even sneeze near them, had a set on my Focus the braking was great but between the bleed screw issues and the actual feel of the levers, I just couldn’t gel with them, it’s probably why people go Shigura.
Tighten them up until you feel them start to strip, then back them out 1/8th of a turn?Just tighten them as if you are tightening a plastic screw and you will be fine.
Tighten them until just before they strip and you are all good!Tighten them up until you feel them start to strip, then back them out 1/8th of a turn?
Mmmm I think I need more cornering control to make up for my lack of skill.
More cornering control to make up for lack of skill?Mmmm I think I need more cornering control to make up for my lack of skill.
When is the Highroller 4 coming out?
My eeb needs more powah and a biggerer battery to keep my rolling speed up!Mmmm I think I need more cornering control to make up for my lack of skill.
Nah they roll slower than the Highroller 3 though...
Not a Maxxis tyre though.
