Stredda
Ok, that makes sense.Was originally to have a smaller hole through the rim. Enve don't drill their rims, the holes are moulded in, and the smaller hole makes for a stronger seat for the nipple.
I learnt the hard way too for my first marathon.Well, I suppose runners have had issues with covered nipples for a long time....
That is such bad design. Even if there was an aero benefit it's no use at all off road and the fact that one broken spoke makes the wheel unrideable is piss poor design especially when the chances of a stick flicking into the spokes is real.Major pain in the ass. My Enve XC wheels that got promoted from MTB to CX/road duties were 28 spoke and very highly tensioned at a 130kgf if I remember correctly.
A broken spoke meant the wheel was now jammed on the chain stay and with internal nipples, there was no possibility of tweaking the opposing spokes to get home, it was a taxi job on at least 2 occasions.
I detensioned and spoke prepped those wheels to 110kgf and have not had an issue since, though they don't get ridden much either now.
I would ring the CEO and give them a spray and send him/her a bill for the taxi.![]()
It is PITA but all to make a pretty wheel. I have old Enves that have been put on the Nickel. I like the clean look but it is a bit of a character test replace a stealthy nipple and/or busted spoke. They are a nice wheelset and I do like them, but minus points for form over function.Major pain in the ass. My Enve XC wheels that got promoted from MTB to CX/road duties were 28 spoke and very highly tensioned at a 130kgf if I remember correctly.
Take my money!!! Even though my V1 is already awesome
The firmer top out spring would be nice but honestly don’t notice the top out on the trail, wider HBO hopefeully means you can use the last 30mm of travel. Email already sent to see if v2 parts can be dropped into v1.Take my money!!! Even though my V1 is already awesome
I can't say for sure, but my personal experience is limited to converting some 27.5 Fox 38, to 29er. All that was required was just change the lowers over. The extra length is actually in the dropouts, meaning the internal chamber of the legs appears to be identical dimensions to a 27.5.Cool to see the smashpot finally coming for dual crown forks.
I guess the DC version just has a much longer top shaft, and the spring mounts lower down on it...
One thing I am interested to know, from Steve himself replying to comments on pinkbike...
Steve mentions the smashpot is the only coil setup that the coil sticks out the bottom of the stanchion... That stanchions have been getting shorter over the years. Even though lower legs have been getting longer (27.5 then 29)
Is this the case?? I know short travel / xc forks run shorter stanchions / less bushing overlap, but assumed that on long(er) travel forks, with increased space in the lowers for more bushing overlap, that it was being used properly...
I am stuck in the distant 26" past, but as an example, Marzocchi would use the same chassis on all travel options of a given model, and set the lower bushing depth according to the travel specified. (shorter travel, more overlap)
But -> all of their (Single crown) forks, whether it was 100mm or 190) had enough room INSIDE the stanchion to house the coil completely.
So, are modern forks skimping out on stanchion length and bushing overlap to reduce weight???
Self quoting. Vorsprung replied and only the top caps and main spring are interchangeable. Everything else is new.The firmer top out spring would be nice but honestly don’t notice the top out on the trail, wider HBO hopefeully means you can use the last 30mm of travel. Email already sent to see if v2 parts can be dropped into v1.
Changed to lighter spring and still can’t bottom out. Even on big hits still have 30mm left. When it’s apart next will shuffle all shims over (think you said you moved a couple) as seems silly to buy a shim kit from Dougal to use all the travel.I wonder how many folk that can't use the last bit of travel in the Smashpot bothered to re-shim the HBO? It's pretty easy to do.
(...but I had too firm a spring-rate in mine so never got near bottom-out anyway.)
chrisking.com
Got a @beeb special and have a smashpotted Z1. To smash into everything.Must have missed it, did you put a smashpot on the Mezzer ?
Got a @beeb special and have a smashpotted Z1. To smash into everything.Was running a CC Helm which I must list for sale soon.
Fark, I've really go to start remembering who I sell stuff to - sorry mate! I thought in your earlier post you were talking generally, not about the specific fork.Got a @beeb special and have a smashpotted Z1. To smash into everything.Was running a CC Helm which I must list for sale soon.
Smashpot is known for not getting last 30mm of travel unless your hucking cliffs. Dougal sells a shim kit to get this last 30mm so may do this not sure as yet.Not the same but the Push ACS I had came with a 55lb black spring, after 1 ride I contacted Cyclinic and said it was too stiff. I went 2 springs lower to a 45lb blue... which they sent me express for free and arrived the next daywhich made the sag correct and felt loads better.
I only had 5psi in the bottom out damper and still never got full travel out of that fork.
But it's $92NZ + postage. For all of about 20 shims, (probably less) and his drawing / graph.Dougal sells a shim kit...
