Don’t say Onyx.How much money have you got?
not sure, to be honest. This bike is probably overkill for me - perhaps I should move the whole thing on and stick to my Aldi 29er But then I'd need to steal it back off the missusHow much money have you got?
add more grease to the freewheel, i just rebuilt my factor E hub with more grease, its much quieter now!My Giant Trance has a ratcheting rear hub, that drives the family crazy when I ride with them. Any idea what's involved in swapping it to a silent hub? Would I be better off just selling/swapping them?
I heard it increased the chances of gumming up your pawls, slipping, and munting stuff... @The Duckmeister?add more grease to the freewheel, i just rebuilt my factor E hub with more grease, its much quieter now!
You don't need much in there, just whack a bit on the drive gear and let it sort itself out. I've never had any problemsI heard it increased the chances of gumming up your pawls, slipping, and munting stuff... @The Duckmeister?
That little bit is enough to quieten down a noisy hub?You don't need much in there, just whack a bit on the drive gear and let it sort itself out. I've never had any problems
Star ratchets are pretty quiet with a fresh coat of special grease.The DT star ratchets can be pretty noisy when dry, so they probably just need a bit of lube between the drive plates.
Some hub designs are fundamentally noisier than others, but a little bit of carefully applied, appropriate lube goes a long way to shutting them up.That little bit is enough to quieten down a noisy hub?
Enough to shut up a family hopefully.Some hub designs are fundamentally noisier than others, but a little bit of carefully applied, appropriate lube goes a long way to shutting them up.
Yes, sell/swap family!My Giant Trance has a ratcheting rear hub, that drives the family crazy when I ride with them. Any idea what's involved in swapping it to a silent hub? Would I be better off just selling/swapping them?
Ok. Box Stealth.Don’t say Onyx.
Well played.Ok. Box Stealth.
And if it's currently a 36t DT... I've got an 18t one here I want to swap with cash your wayGo 18t. Almost silent after a fresh greasing
