Decided to do another bike build as there is just something about riding a bike you have put together yourself.
Ended up with a Octane One Prone 27.5 frame instead of the planned Brand-X HT-01. Better in the long run as the prone is more modern with 12mm thru axle and better cable routing for rear mech. A 1x frame only. First ride with the bike proved that I was being lazy with previous bike in using the granny. 32t up front and 11-42 rear seem good enough for local terrain.
After researching the web, end up using the XT M8000 11sp rear mech for the 1x10 drivetrain as no need for rad cages or wolflink to cope with 42 rear cog.
Frame - Octane One Prone 27.5
Rear shock - where do that go?
Front shock/fork - 2010 Fox Float 32 140 mm travel 26"
Handlebars - Wake 720 low rise
Stem - Funn Stryge 60 mm
Headset - Gus G800 IS42/IS52
Grips - Lifeline lockon grips
Saddle - WTB SST
Seatpost - IXL 125 mm external dropper
Front brake - SLX M675 with 180 mm CL rotor
Rear brake - SLX M675 with 180 mm CL rotor
Cranks - XT M780
Chainguide - NA
Chain - 10 speed
Pedals - Rockbros alloy
Front derailleur - NA
Rear derailleur - Shimano XT M8000 medium cage
Front shifter - NA
Rear shifter - Saint M820
Cassette - Deore HG50 11-42
Front hub - DT Swiss 350
Rear hub - DT Swiss 350
Front rim - DT Swiss M1800
Rear rim - DT Swiss M1800
Spokes - DT Swiss
Nipples - DT Swiss
Tyres - Schwalbe Tough Tom 26x2.25
Tubes - Yes
Saddle - WTB SST
Cranks - XT M780
Chainguide - NA
Chain - 10 speed
Front shifter - NA
Spokes - DT Swiss
Nipples - DT Swiss
Tubes - Yes
