I just recently replaced my worn Maxxis Tomahawk with Michelin Wild AM (front) and WTB Trail Boss (Rear). Wild AM was originally bought for the rear, but I needed a new front tyre and I thought oh why not try it in the front.
First ride out, the Wild AM had some sketchy moments, quite scary when tilting around corners, felt like the side knob would disengage at any time. The trail boss was fast and good. No complain. Bite well to normal semi loam trail, not sketchy in sand or loose dirt.
2nd ride out, I lowered the front pressure from 20 to 19, and the Wild AM turned good! Tilted it around loose stuff, climbed rocky uphill, no issue.
More test ride will be needed to ascertain its quality, but so far I'm impressed.
I'm really impressed with the Trail boss. I'm well aware that the casing is extremely thin, but then I'm only 60kg kitted up. I figured as long as I'm careful where I place my tyre (ok most of the time) and use higher pressure than I normally do (24psi), it should last "ok".
Heading out to Canberra for the long weekend to ride. I've installed WTB Convict 2.5 (front) and Trail boss 2.4 (rear), both with TCS tough casing. I'll find out how good they are compared to my stock go to Magic Mary front 2.35 and Minion DHR 2 rear 2.4WT.
