skinnybeans
I compromised and got hope stem spacers instead. Brrrrap!
For sure. Think I'll just get some more spacers for now and see how it goes.it's coming along nicely,as for looks, definitely go for function over over looks,you would rather be comfortable on your bike as a posed to looking like a modelhoto:hoto:hoto:hoto:hoto:
Only got a 20mm rise bar!Get yourself a 30 or 40mm riser bar
Chops is next level hustle...I've got a stem that will fit your bmx bars in anno red. Yours for post if you promise to run the big bars on your first ride.Wow that was a comprehensive answer! You should sell your services to chops.
I do have some 8" rise bars on my bmx... maybe I'll put those on it and slam the stem. Different bar diameter I think but why let that ruin a stupid idea??
The internal brake routing scares me a little so might try tackling that next. Probably need to chuck the handle bars on so I can attach the lever.
Hahaha that's a tempting offer! I've actually got an old 90mm raceface stem kicking around somewhere that I know isn't 31.8 (realised after putting it on a bike and trying to fit handlebars) but don't know if it fits bmx bars.Chops is next level hustle...I've got a stem that will fit your bmx bars in anno red. Yours for post if you promise to run the big bars on your first ride.
Going to thread the brake through then cut it to length afterwards. Might be tricky bashing the new barb in but I'm sure I'll manage.
Putting zees on. I do have the yellow blocks. Took it around to my parents place who have a vice in the shed and got my brother to hold the frame up while I clamped the hose and tapped the barb in! Damn internal routing making things difficult...What brakes you putting on? If it's Sram then no problem with the barb it screws in. If Shimano or Hope it helps to use yellow cable gripper blocks in vice grip pliers then just tap it in with a hammer by leaning the pliers against something solid like the stem cap (wrap in towel first)
I have put on cable ties, it has helped a little still rattles a bit though. Didn't really notice all that much weekend think I was more concerned with trying to not hurt myself that worry about noise!Ser those loops at the cable entry points in the frame? Fasten the cable to it with some cable ties. That helps somewhat.
