PNW Loam Dropper Lever
smitho
Can anyone with a PNW Loam Lever confirm that the interface is exactly the same as that of a SRAM shift lever? Trying to find a lever that will attach to direct mount attachment on Hope Race lever.
No idea about the loam but the wolftooth has a bazillion adapters and the Bikeyoke lever is matchmaker out of the box.
I was also reading somewhere (nsmb maybe?) that the Magura, Formula and Hope lever backplates are interchangeable. So that might give you more options.
Is this what you are after ?
The matchmaker adaptor has a lip on both sides, the PNW adaptor has a lip on one side. The matchmaker will not fit on the PNW lever without modifying it.
372475
372476
smitho
Cheers - I’ve got a wolftooth, but the older Hope Race Evo levers. No way of making them match.
shiny
Go-go-gadget-wrist-thingy
Can’t you use the SRAM adaptor for the Hope and get a matchmaker adapter for the wolftooth or I am missing something?
smitho
The Hope Lever sram adaptor is what I have. It allows a shifter to mount directly.
The Wolftooth Hope adaptor fits Tech 3 levers but not the Race Evo levers.
The Wolftooth SRAM adaptor allows it to be mounted to SRAM levers but is a different mount to shifter and not compatible with the Hope adaptor I have.
Yep - only had a couple of rides and in as new condition. Comes with standard bar clamp, Hope adaptor and (if I can find it) a SRAM adapter too. PM me if you're interested.
If Hambo doesn't jump on it, please let me know. :)
