FatMuz
Mine is same colour scheme but in the Prime....Oh i like that very nice :thumb:
Also running a DVO Diamond fork and a Fox Float X2
Thanks mate.. Really just taking the jump to 27.5". The Pivot Mach 5.7c did everything I wanted it to. Most rides would see it using most of its travel. Just trying to not go backwards now. After something pretty similar really.Ah right, seen your post on mtbr & PF. I have Stans Flow EX on mine and an Ikon rear/2.3 DHRII front, I don't find it hard to pedal ever usually and I also ride it on the roads to/from tracks.
Mine is about 12.7kg without the saddle bag and it has 2x10 XT drivetrain, Pikes & hope brakes. It could be more playful sometimes, but that is easy to rectify by going faster. The bike is a lot better than I can ride it - there are a few reviews comparing the Pivot Mach 6 to it and the general consensus appeared to be that the HD3 is a much better bike overall especially climbing.
Is your pivot too much bike, not fun enough, or something? What is the reason for upgrading?
Highly doubt it'd be backwards, more likely a step up . I haven't ridden the Pivot though, but wouldn't give up my HD3 for anything.Thanks mate.. Really just taking the jump to 27.5". The Pivot Mach 5.7c did everything I wanted it to. Most rides would see it using most of its travel. Just trying to not go backwards now. After something pretty similar really.
Not quite sure if you've said in jest... because I can't fit a bottle and cage in there HAHAHA This is a small sized frame. I think the larger sizes or other models have the bidon bolts on the underside of the downtube.Piggyback shock & room for a bottle.
Well done Rocky Mountain!
I was running this combo the same way. The HR2 on the front was all good. I found the DHF on the rear not as grippy as the Ardent I'm running now, especially on climbs.Looks great. How does the DHF rear and HR2 front combo go, I've only ever ridden that the other way round
yes it's a bos Kirk super light weight with high and low speed compression and pro pedal leaverWhat shock is that running Ben?
I have no troubles, but I am far far away from being a rider that pushes them. When I go tubeless I plan to switch them around, I have had the front wash out a few times, still working on cornering technique.I was running this combo the same way. The HR2 on the front was all good. I found the DHF on the rear not as grippy as the Ardent I'm running now, especially on climbs.
Hmm, curious - is that an older lyrik with a 650b wheel stuffed into it? Also I assume that's an ava cart in it?Had this since April:
So what is "trail riding" that All Mountain and XC are not?
I'm lost....
I'm giving away my age (and prejudices) here, but it's still simple to me:So what is "trail riding" that All Mountain and XC are not?
I'm lost....
