Post your commuter!
My commuter is for sale as it has been replaced
Awesome. Is it as easy as getting a new single chainring and removing all of the unnecessary bits?
Thanks
Sent from my iPad using Tapatalk - now Free
pretty much! depending on how you go, you may need a simple guide to stop the chain coming off, otherwise you can go the narrow-wide ring and clutched derailleur route.
My new commuter and first foray into pavement bikes!
'13 Specialized Secteur Expert
I am looking for a nice steel frame to turn into a commuter bike - have a penchant for a mixte (for the standover height) but anything that fits will do. I have been commuting on my ill-fitting road bike and whilst it is nimble and speedy, it makes my shoulders and back curse and that makes me not want to ride.
So I am wondering - how much luck would I have in swapping out the majority of components on my roady onto an older steel frame, like a mixte? In particular the groupset and wheels.
Or am I better off just splashing out and building a rigid steel 29er that I can use on and off road? (I dont have a hardtail... so its looking like a tempting option) I have thought about putting slicks on my xc bike but commuting on a dually is really a bit overkill... there aren't any stairs or anything even remotely fun on my commute ;)
sorry if this has been discussed before - I have not read through all 21 pages yet.
Cheers!!
Slicks, 1x9 and rigids to come. This was free (cheers Dad!) so I'll keep track of how much I spend and see how bling I can make it for as few peanuts as possible.
Cheers!!
Most of the roadie cockpit probably won't fit an older steel frame with its narrow seat tube and headtube. And many older mixte frames aren't 700C (unless you get lucky) so your wheels may not fit properly. Groupset 'should' be able to make the journey but the brakes may not and the FD might also be a poor fit. Final chainline may be compromised depending on the type of crankset too.
I have two suggestions for you.
One is pre-built: Norco Threshold - not a mixte but it is steel and a great price for a do most of it disc cross commuter bike. There's others like it but this is a nicely set up bike for the money.
The other is a DIY: Singular Gryphon - steel, drop bar 29er gravel grinder. Larry's Custom Cycles in Melbourne might have a frameset your size?
Thanks for your reply SBD :) I thought it would be a pain to swap out modern to oldschool... probably end up costing close to building or buying something new straight up.
I'll go check out the norco if they have any smalls in stock at 99bikes in brissy, the singular gryphon is sweet but far too big for me though :(
Thought I would share this interesting piece, made up from bits and pieces I had lying around (well plus other stuff from the trading section). My commuter:
Giant XTC Hardtail Frame, Aluxx, for 26" Wheels.
Mosso Rigid Disc Fork (Ebay, $70)
Shimano M475? brakes - from the XTC - super reliable.
Ultegra Compact crank
Currently 9 speed 12-23 with gripshift, but soon to be 12-27 10 spd with new shimano shifters and keeping the 9 spd X9 derailleur (since this works with 10spd Shimano)
29er MTB wheels with Roadie 28mm Schwalbe Marathon Plus tyres.
560mm flat bars, soon to have some ESI chunkys on there.
Things of note:
-The Ultegra crank arms clear the chainstays by 3mm
-The 50T clears the chainstay by 3mm
-Rear tyre clears the chainstay brace by 5mm, front tyre clears the fork easy.
-Getting a MTB FD to work with an ultegra crank was a massive pain, but I got it to not rub in all but small cog - small ring. It changes rings quite well actually.
-When in the big ring the crank arms clear the FD cage by about 2mm
-I modified a MTB BB to fit the ultegra crank (i.e. I'm running it without the plastic spacer thing in the middle and only one BB spacer (since the spindle is shorter than a MTB one)
Struth! Better hope the frame doesn't flex at the BB or you're going to get a whole bunch of rubbing in a whole bunch of places you don't want it to.
Here's my effort. It's a Giant Cypress 700C frame set from the early noughties with a basic Novatec/Alex 36h wheelset from the cross bike wearing 700x42 Maxxis Wormdrive tyres.
Drivetrain is a square taper with the rings drilled off and replaced with a Hope 40t ring, 11-32 XT cassette and X9 type2 RD are from the mtb. Bars are Salsa Woodchipper 2 with TRP levers and X7 shifter tucked close to the stem using a FD mount and some electrical tape. I had to replace the one bolt Giant post with a USE Shokpost as it failed and am now even more comfy
^^ I like that. I was hoping to see some more Frankenbikes in here, and that certainly is a special one.
Its a fixie. Double functions as my pub bike.
Despite the somewhat reasonable spec (most notable points are Thomson seatpost and CK headset) I really don't care about it.
If it is stolen I've already saved more money riding it than I paid for it, and its pretty identifiable.
When it dies/is stolen the world will be a better place anyway - one less fixie.
golly gosh that is offensive!
i'm trying to buy a commuter now, would you believe how hard it is to buy a bike?
all i want is disc brakes (for compatibility with my other wheels) and sub $800... i dont think anyone has anything available.
If your offensive comment is referring to my commuter shitter then it's that way so it stands out in traffic. I can't believe I was originally thinking of spray painting the whole thing black.
Anyway, the trick is haggling. I got mine half of what its worth. If that.
yep! in a jestful way. ;)
Here's my ironic hipster super commuter. I ride 20km each way to work. Its a really columbus steel roadie I used to race 15 years ago. Old shimano spds. ODI lockons. Massive shimano exage front brake lever. Originally an 8 speed cassette with 6 speed Dura ace downtube shifters, but the miss-shifts really were a bit much. Now has an LX 9speed shifter from a giant ATX2 and a new tiagra cassette. I'm looking to get a wolf tooth 42T CX narrow wide chainring and going 1x9.
And a set of gold pro tapers from the late 90s early 2000s.
http://i225.photobucket.com/albums/dd32/oliosky/d9fc56c0a3e311e3b7d512b0a3aaf2c4_8.jpg
