Adminerotic
Odd they chose to mount the fuel tank so high. I expected a drop tank.
Opel Manta column so quite similar set up. Wonder where they got their uni joint from...
hifiandmtb
Sphincter beanie
I bet they worked hard to get the column perfectly inline too. Because they can.
[edit] I tell a lie - must be the same as yours as they are using the same bulkhead hole & do t have anything fancy inside the cabin such as another UJ or whatnot.
If Gordon’s ok with slightly crooked then everyone should be happy!
Adminerotic
The pedalbox gets in the way of a straight run through the firewall. I guess you could do it with multiple joints but lots of work.
Adminerotic
With a weekend lost in Melbourne I spent this morning doing the gearbox crossmember. I had a design in mind that used a horizontally mounted circular mount and a pipe cross member. Bought a cheap mount online and it was enormous! I then used a spare Pinto engine mount we had mounted vertically. Even then I expected to have enough space to fold some 3mm sheet and pretty it up with dimples but in the end there was no space. I used a short length of rollcage tube and squashed the ends in the press and welded these to some 5mm plate. This in turn is bolted to the plates welded onto the chassis by the previous owner. The press has had a hard life before me so squishing pipe was tedious. The bottom of the gearbox is canted 8.7 degrees left to right and 5 ish front to rear (I got the specs wrong, I am allowed up to 15 degrees fore and aft). The mount is vertical and the attachment to the gearbox takes up the angles. Final welding to the fixing plate will be done once the engine mounts are done. Will try and knock those over this weekend though I have some other things on.
Enough words, time for pics.
Installed, gearbox isn't quite centred here but the top section isn't welded yet.
And some welding for @pink poodle
The gearbox weighs about 43kg full of oil and taking half the weight of the tailshaft. I worked out the loads on the two engine mounts and the single gearbox mount and then made it strong enough for 10x that load plus a safety factor so it will be plenty strong enough.
SummitFever
Welds look good. In relation to the "plates welded onto the chassis by the previous owner", will you pick them up on the inside with the cage or otherwise reinforce them? Those old chassis are typically so flexy that a seriously non-compressable piece like your gearbox crossmember may be the strongest thing across that part of the car. Big thick plates welded onto thinner pressed steel can often lead to cracking at the HAZ (esp. if the previous owner was not meticulous with his cleanup before welding).
Adminerotic
Previous owner was a panel beater and built the body to rally spec, seam welded and chassis is reinforced and all solid. If I wasnt happy I would have plated the ploor and made a shorter mount but it is all very strong.
He was planning on a turbo YB and Sierra Cosworth 5 speed. The location of the plates is almost perfect for our combo which was nice.
I might be onto an early YB myself, not that I would put it in this. Too late now.
Adminerotic
A spare? Where did you find one...
I gave three Pinto engines away. They were the 2L OHC engine sold here in the Escorts but I guess you mean the whole thing. Horrid, horrid engines. Cast iron everything and cam lube is via a thin copper tube that gunges up and ruins the head. The block though was the base for the YB. You can buy an alloy Pinto block now.
Adminerotic
On the subject of Cosworth engines, this doco is worth a look:
The Minardi 2 seaters have the V10 Cossie engine. I have a conrod, valve, timing gear and finger follower. Amazing engine with pneumatic valve springs and motorcycle like engine speeds. There are a few articles breaking down that engine and looking at the technology. Pretty amazing. I have a fair idea of the basics of this current era but the detail would be stunning.
hifiandmtb
Sphincter beanie
Watching an old Harry Metcalfe vid & decided to cyberstalk his house location based on landmarks & shops he drove past. Because fun & creepy.
here
Adminerotic
Engine mounts done and gearbox mount completed. Relatively straight forward. Tube notched the pipe to suit the mount outer section and weld in place. The pipe also looks like seamless rollcage tube so probably a low Cr low Mo steel. Air cool rather than quenched. Pressed in the mount and the fitted that to the frame that was welded up. The only tricky bit was cutting the pipe to length at the right angle. For that I used the notcher to cut some 40mm pvc pipe and then trimmed that back and forth until it was the right length and then one more measure and cut the pipe support. Happy to sacrifice that than cut the support too short!
Lie under the car and tack weld in situ and remove to weld out. Once the engine mounts were done the gearbox was centred finally and the last piece of that mount tacked. This bit is interesting because there is not a lot of space under the middle of the car for me and a helmet. Anyway all done now. Need to trim a little more off the crossmember flange but that will only take a few minutes. Final positioning of the chassis mount and a stiffener to be done. Will try and get the front suspension fitted up tomorrow and then spin the shell around to concentrate on the diff. First to swap the 5.1 gearset out for a more useable 3.89:1 and then work on the Watts linkage and trailing links. Diff is a heavy bastard of a thing.
The tape drive belt is holding up well.
Adminerotic
Me again. Fitted the engine we will be running to finalise ancilliaries and locations for mastercylinder reservoirs, catch can, evaporation and expansion tank etc. Fuse box and wiring in the engine bay will also be fitted. Dip stick tube has been bent and fitted but I still have to check levels. The engine and box will come out to paint the engine bay then final engine fitment and exhaust. Changing the crownwheel and pinion and then mounting the diff and links will be the next step. Injector holes will be plugged and the rail removed.
Changed the dome filter for a box, much better fitment. Still have a good 45mm above the inlet trumpets.
This gives an idea how far back we can run the engine. The centreline is about 100mm behind the front axle line. The normal heater bowl sits through the block and head!
These are stock XR4 headers, compared to
These.
Next project is lined up too, will look a lot like this
Rwd or awd is the question...
