Can you get kits here?
I imagine so. They’re super common calipers found on about a 100 different euros.Can you get kits here?
Just in case anyone goes to try this - Be wary of sand selection and make sure it is totally dry (as in dried in a low temp oven dried), otherwise any steam that would be generated from heating the damp sand can explode the pipe. (ie: thin walled pipe is not a great pressure vessel AKA accidental pipe bomb shrapnel whoopsie!)Not my project, but this channel is pretty cool.
Production quality, music selection, and project build is very soothing
Worth a sub and I few likes
I'm not even sure what I'm looking at. Do these FWD abominations have a live rear axle? ie. no independent rear suspension? Is this car from the 70's.
It’s called a torsion beam axle, super common and under the back of many many FWD cars.I'm not even sure what I'm looking at. Do these FWD abominations have a live rear axle? ie. no independent rear suspension? Is this car from the 70's.
Renault weld in a sway bar inside the beam. Presumably the Nurburgring Cup spec has a stiffer one than thisA live rear axle on a fwd would make it an awd . As haakers said very effective when engineered properly, cheap and lighter than trailing arms and chapman struts. I have stiffened up the one in our xr4 with a 'sway' bar and added camber plates to get -4 deg of camber. It is set up for trailing throttle oversteer. Just dont lift quickly or you see where you came from.
** goluf* golf
I STAND BY WHAT I SAID** goluf
Me too! No need to shout.I STAND BY WHAT I SAID
CAPS LOCK IS STUCKMe too! No need to shout.
Try using a white font.CAPS LOCK IS STUCK
STOP TELLING ME HOW TO LIVETry using a white font.
Are you and @moorey are the same person?STOP TELLING ME HOW TO LIVE
ONE TWO MANY ARE’S THERE BUD.Are you and @moorey are the same person?
