Another weekend working on the cars.
XR4 got bigger front rotors, a diode back to the ecu so the isolator actually shut the engine off at idle, loooong story. Need a few mods to the roll cage but so very nearly there. Going to trial fit the 3 MPS box to the spare shell and if easy enough that will get into the XR for its first outing after CAMS log books are finalised.
It is not going to be fast at 200hp per tonne but it will be fun. Just testing around my place is great though I guess the neighbours dont think that.
Escort had the engine and gearbox in again for mount set up. Few changes since last time now that the front end is fixed. Needed to drop the engine lower and that means either a modified Gp4 crossmember or I make a new one from scratch. Either is ok. The gearbox is from an NC MX5 and doesnt have individual mounts. I can run a new cross member across the rear of the box and pickup the beam supports on the gearbox with a motor mount. The front engine mounts are pretty striaght forward with chassis brackets and engine plates with isolating blocks on pipe between.
The gear lever falls perfectly to hand and the hand brake from the XR4 is perfect though I will need to mount the seatbelts off the sides of the tunnel rather than the top which was standard Escort.
The steering rack will drop so I will need to change the tie rod connections to correct for the 25mm drop otherwise it will bump steer like a bastard. Same problem as the Gp4 but the other way (lower rather than higher).
Seats are a touch high so I will make new mounts out of 6mm flat otherwise the inside position is good. Fuse box and wiring is being sorted, again another donation from the XR. And dont worry the 17 trillion switches have been culled to 5. Alternator was potentially an issue because the Duratec has a solid mounted alternator that is ecu controlled. Pretty sure i have that sussed and the alternator can be used pretty much as is with stock Focus idlers, water pump and tensioner.
