Asininedrivel
caviar connoisseur
*Porsches excluded. Mk VII Golf Rs still haven't depreciated enough for my liking either.It’s why all German cars have depreciated 90% by the time they are a teenager
Worked it out.Going well so far.
Yay! Must be great to finally know what's wrong....Worked it out.
Pressure regulator was stuck in fully open bypass position, and check valve in the pump is faulty. Replaced the regulator (part of the filter) and now the line doesn’t drain of all fuel between starts.
If I can find the right line for inside the tank (it’s like corrugated crazy straw), I’m tempted to add a check valve inside the tank but outside the pump, the bosch pump is fine otherwise.
Time for an intervention with fire, lots of fire.MAP sensor might helped a bit, but not really. But realised it was pulling a massive vacuum on the crankcase, and the whistling like a vacuum leak might be oil filler cap seal, not a leaking manifold. Oil cap hard to pull off with the engine idling... PCV valve ordered.
Yes, it's a great relief to work out the problem.Yay! Must be great to finally know what's wrong....
Just chuck a new pump in. Hacks i would suggest are best avoided on a complicated beast like that
Swap you a genuine pump assembly for a RUNNING Renault?
Would for the local stealers price. $380 usd from fcpeuro.com though.
Might be able to buy motor local from bosch too. Just need to pop it out of the tank again.
Think I’ll add a pressure gauge on the fuel line. She starts with about a 0.5 seconds cranking time with zero line pressure, but fuel in the line. Unlike before.
by gee, thats the one. THANK YOU. I like this Spareto website, didn't know it existed.7.22013.69.0 - Fuel Pump
7.22013.69.0 - Fuel Pump manufactured by PIERBURG applicable for the BMW. Order PIERBURG fuel pump online and find many other parts and accessories that fit your car, bike or truck.spareto.com
Its good for one off and small order, the shipping is sensible.by gee, thats the one. THANK YOU. I like this Spareto website, didn't know it existed.
it’s from a bmw - probably won’t work and I’ll be stuck with the Reno...You can send haakers the old one to put in a tub of petrol to spray over the renault before fixing it...
It can spray petrol over any brand, don't fret.it’s from a bmw - probably won’t work and I’ll be stuck with the Reno...
I feel that there is a lesson in here somewhere...Changing the rego over on the Alfa, and failed the roadworthy on the bloody window tint... FFS. 29%, 35% +/- 5% allowed...
Didn't even want the tint, was dealer fitted before i bought it. More money to be spent now, yay.
Car dealers are annoying - already learnt that lesson years ago.I feel that there is a lesson in here somewhere...
No, my waters are telling me there is another more racist lesson...Car dealers are annoying - already learnt that lesson years ago.
