Question about tapered forks and non tapered frames....
LoveB
I think I already know the answer to this but I might as well ask,
I've got an xxtension xplore frame. Currently got a fox 36 on it. Was wanting to swap it out for a lyrik owned by a friend. Problem is its off of a remedy so tis got a tapered steerer I'm pretty sure.
Basically, can I fit a tapered steerer into a non tapered head tube? I'm betting no cause obviously it wouldnt go in all the way?
Reubs
square peg, round hole. or rather large peg, small hole. Unless your frame has a straight 1.5 headtube with reducer headset??
Andrei
Measure the internal diameter of your bikes head tube. If it's 44mm then you can get a special headset from nukeproof that allows you to do just what you're suggesting. I use one with my corsair marque and a tapered revelation. Works great but it does add a bit to your stack hight as the lower bearing sits in a cup outside of the headtube.
chuckrockswell
iRide Bikes
chris King also do a headset that will allow you to run tapered in non tapered headtube so long as the OD is 44mm
got one in stock :biggrin:
